Wheel spacing question...
   / Wheel spacing question... #1
helle253
Looking at MF 1648.
What kind of adjustability is there with the rear wheels and front wheels meaning what is std width and how much +/- from that. Input would be appreciated.
   / Wheel spacing question... #2
I just got my 1643, and did notice, and after reading the manuel. they are changeable, Mine are set at 68" and can be set less under 60". This is something I will like here in the future, it keeps me from having to buy a wider tiller.
Looking at my wheel set up it appearse I can go about 8 to 10 inches wider.
I can't see going wider due to 72" rotory cutter.
hope this helps.
david
   / Wheel spacing question... #3
The6shooter is right, on the rear you can turn the rims around, also you can set the outer rim either inside or outside the centre hub, the only thing I'm not sure of is the front rims, you can probably spin those around and widen the stance, but there isn't as much versatility as with the rear.
2017 Chevrolet Express Box Van, VIN # 1GB0GRFF9H1305955 (A51572)
2017 Chevrolet...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
Ground Breaker X Backhoe BH80X 3 Point Hitch Attachment (A51573)
Ground Breaker X...
2007 VOLVO VNL DAY CAB (A52577)
2007 VOLVO VNL DAY...
2022 John Deere 4066M Heavy Duty MFWD Tractor (A53342)
2022 John Deere...
