wheel spacers
   / wheel spacers #1
duster74
does anybody remember who had the drawing of a wheel spacer for a 2520 thanks
   / wheel spacers #2
They are not needed if you are just trying to gain 3pt clearance.
just flip Imatch mounts to inside, and you'll have 3+ inches on each side....
not sure on the spacers tho......
   / wheel spacers #3
Spacers for the front or back?
   / wheel spacers
for the back. somebody had a detailed drawing but i cant rember who. i think they where 2 or 3 inches. thanks
   / wheel spacers #5
The front I knew about but the rear I couldn't locate. Sorry. Good Luck
   / wheel spacers #6
The member was nate m but watch you bolt size because my 2520 was
different. I also made mine only 1.5" and also added a counter bore to
sit on hub of axle. You might try turning your wheels around but be sure
to change from side to side for tread direction. Sorry I can't post my
print I don't have the means to do so.
   / wheel spacers
thanks for the info
2013 Infiniti G37 Coupe (A55853)
2013 Infiniti G37...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
New Holland C185 (A47477)
New Holland C185...
BUNDLE OF 96" X 40" DIAMOND PLATE SHEET METAL (A54756)
BUNDLE OF 96" X...
UNUSED LANDHONOR MGB-72-44W 44" MINI GRAPPLE BKT (A54757)
UNUSED LANDHONOR...
SELLICK S60J4I-2 ROUGH TERRAIN FORKLIFT (A52705)
SELLICK S60J4I-2...
