Wheel spacer??
   / Wheel spacer?? #1
JKR
Washingtonville NY
JD 3033R
I have a new 3033R with 4" wheel spacer. It made a huge difference when out in the rolling field.
The question would front wheel space work and to the STABILITY of the tractor. I can't find a answer.
Any one using front wheel spacer.
   / Wheel spacer?? #2
If your front axle pivots in the middle (as does my 3320) then front spacer will have no effect on stability, except if it goes over far enough to hit the pivot lock point.
   / Wheel spacer??
Thanks I though so but wasn't sure
   / Wheel spacer?? #4
I have a pair of 4" rear spacers on the rear of my 3720. It put my rears out far enough that a 72" rotary cutter extended a mere 6" on either side of the rears. But doing so ended up putting my front wheel footprint inside that of the rears. Results; two sets of tracks (four total) on soft ground/snow. Plus the forward view became an inaccurate gauge of how far to stay away from fences/treelines/etc when mowing. So I added a pair of 2.5" spacers to the front. That squared up my front/rear footprint, gave me a forward sight line for the rear mounted mower, and set the outside edges of the front tires to the same width as the 60" front bucket..
Bottom line, the center pivot design relative to stability held no influence over my decision to add front spacers. Given the other benefits already described, I felt it money well spent
//greg//
2005 CATERPILLAR 730 OFF ROAD WATER TRUCK (A51406)
2005 CATERPILLAR...
2000 Sterling L9513 Winch Truck (A53473)
2000 Sterling...
2025 K4230G UNUSED Metal Storage Shed (A53117)
2025 K4230G UNUSED...
2002 Freightliner FL112 T/A E-One Pumper Fire Truck (A51692)
2002 Freightliner...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2010 UTILITY TRAILER MFG. CO. 53 FOOT FLATBED (A53843)
2010 UTILITY...
