Wheel Motor Leak
   / Wheel Motor Leak
Thanks for the info. I was looking at that hub on the tappered shaft and wondering if I should take it off. I do have a large puller. Maybe sinse mine is fairly new it will pop off easily. When you put it back should it be torqued or just tightened with a wrench.
sg
   / Wheel Motor Leak #12
Just leave the hub on, let PT deal with it, if not torqued correctly the hub will come loose and destroy the hub and shaft. It is not necesary to remove the hub to remove the motor as it was on early models. Also do not remove the motor bracket with the motor, just remove the 4 bolts holding the motor, will save you some freight, the bracket is heavy.
The hose are #8, not #4 as stated by another poster.
Good luck,
EB
   / Wheel Motor Leak #13
</font><font color="blue" class="small">( Just leave the hub on...It is not necesary to remove the hub to remove the motor as it was on early models.
)</font>
Thanks for the correction...I didn't know this was not necessary on the newer models!
Dave
   / Wheel Motor Leak #14
</font><font color="blue" class="small">( Left front wheel motor on my 425 started to leak at 38 hrs. Not a bad leak just a drip that makes a mess on the wheel. )</font>
Clarke,
I assume the repair to your wheel motor was successful.
I too have a wheel motor leak that started at about 25 hrs. The left rear wheel motor leaks when the hydraulic fluid is hot and when working the PT hard (lifting, digging, etc.). I called Terry at PT right away and he told me to just watch it and see if it stops or continues to leak. He said if the leak continued he would just send me a replacement wheel motor in exchange for my leaking one. I have had to add about a half a quart of oil per 10 hrs of operating time. As soon as I have time I will call Terry for a replacement. It sounds like they may have had a bad batch of wheel motor seals. I purchased my PT 425 on 5/7/04 and just finished my 50 hr maintenance today.
   / Wheel Motor Leak
When my wheel motor leaked Terry did not offer to exchange had to send unit back. After a week of waiting called to find status Terry told me they never received the motor. Tracking the UPS shipment I found they did receive the motor and misplaced it. Anyway almost two weeks latter had the motor back which was the original since I had recorded the serial #. Has worked fine since repair. Have had no other issues with tractor about 90 hrs. at this point. Soon the machine will be put to the test again starting to build garage.
sg
2022 Coras Predator Steel End Dump Trailer (A56435)
2022 Coras...
2008 FORD F-350 SUPER DUTY BUCKET TRUCK (A58214)
2008 FORD F-350...
2012 PETERBILT 388 WINCH TRUCKS (A58214)
2012 PETERBILT 388...
2014 Ford E-450 Super Duty Shuttle Bus (A56858)
2014 Ford E-450...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
New Wolverine 3Pt hitch Receiver (A59000)
New Wolverine 3Pt...
