Wheel Motor Cross Reference?
   / Wheel Motor Cross Reference? #1
dannygw
Bronze Member
Bismarck, ND
Power-Trac PT425 purchased May 2004, John Deere 1025R , Dec 2013
Does anyone know the cross-reference # for the PT425 front wheel motor, with parking brake? It is different than the rear wheel motor which is White # 400230W3122AAAAA. I called Central Hydraulic and without the White # they cannot help. This is the newer White wheel motor, circa 2003 - 2004, with more torque, the White CE series 400 motors. Thanks.
   / Wheel Motor Cross Reference? #2
The parking brake is a flange on the wheel hub, not a part of the wheel motor. The front and rear wheel motors are the same.
Thanks KentT. I guess I will have to wipe some more oil off of the motor and give it a better look when I get home this evening. I would have swore that it was a different motor.
   / Wheel Motor Cross Reference? #4
Well, I may have spoken too soon, but I don't think so. My older model 425 had the same White RS series motors on all four wheels. I don't know why they'd change that practice when they went to the White CE series motors, since Tazewell typically takes the simplest approach to everything, it seems...
   / Wheel Motor Cross Reference? #5
I've changed 3 of my 4 and each time the standard $150 wheel motor would not fit and I had to get it from Pt at $500+
   / Wheel Motor Cross Reference? #6
The parts manual for my Dec 2010 PT-425 has the same part number for all four wheel motors. So, I assume front and rear are the same, at least on the newer models.
   / Wheel Motor Cross Reference? #7
The wheel motors would have to be the same displacement plus additional components for brakes.
   / Wheel Motor Cross Reference? #8
The brakes on the PT425 front wheel motors are external and all it is is a slotted disk for a pin to engage when parked. I have a picture here somewhere. :confused:
   / Wheel Motor Cross Reference? #9
Here's a cut and paste of a post I made back in 2007 regarding the wheel motors on my 2001 PT425. The last three, in particular, show the parking brake and pin arrangement....
As requested, here are some pictures of my left, front wheel motor mount area on our 2001 model year PT425 with the old style wheel motors...
All of the steel for the motor mount appears to be 1/4" thick.
1. Depth of motor mount box is 6.25".
2. Width of motor mount box is 8.5".
3. Height of motor mount box is 4" and is flush with bottom of skid plate.
4. Shows the hole for the rear of the wheel motor and the hoses. The wheel motor box appears to be centered on the hole, 2.25" from either side.
5. That makes it 4" wide.
6. And 6.75" high.
7. Looking down, shows wheel motor, parking brake pin with locking spring at the bottom, and wheel hub with notches for parking brake pin.
8. Side view of wheel hub. Note parking brake pin at bottom right, engaged.
9. Closeup of engaged parking brake pin.
That's it. Hope it helps.;) Attached Images
   / Wheel Motor Cross Reference? #10
I believe the larger PT's, have spring applied brakes, and hyd release built into the wheel motor.
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A53472)
Michelin CARGOXBIB...
Tradewinds Power Unit (A50120)
Tradewinds Power...
2018 John Deere 310L 4x4 Extendahoe Loader Backhoe (A52377)
2018 John Deere...
2016 KENWORTH T270 S/A SERVICE TRUCK (A51247)
2016 KENWORTH T270...
New/Unused Radiant Cooktop (A51573)
New/Unused Radiant...
