Tires wheel fell off
   / wheel fell off #1
dixstir
fairmont mn
2305 jd cub farmall home made tractor
got a chance to use the 2305 today pushing some snow didnt last long dont work to good on 3 wheels bolts all fell out got it inside to see what went oops cleaned out the threads need 5 new lugs next steep was to check the other wheels but they are all tight so dont know what happened just about 2 years old minus a few days.
   / wheel fell off #2
I take it you haven't been checking wheel bolt torque frequently, as called out by the manual?
   / wheel fell off #3
Check the rim over also for cracks. Loose lug nuts put a lot of strain on the rim around the bolt pattern and since your wheel actually fell off it was under a lot of strain and its possible you cracked the rim.
   / wheel fell off #4
Punctuation helps a lot.
   / wheel fell off #5
I'll add another post...once that wheel is re-installed and you've checked torque on all the wheel bolts (all four wheels), I suggest you consider torque striping.
Pretty simple...using a contrasting color paint marker, mark a stripe across the bolt to the adjacent wheel surface. As long as the stripes are aligned, your torque is OK. If they're misaligned, the bolt has loosened.
   / wheel fell off #6
Does proper punctuation fix his problem? If he is posting from the TBN app on his smart phone its more of a hassle to do punctuation then from a keyborad on a computer. And regardless, his problem is the same and he is looking for advice on fixing the tractor, not his punctuation.
   / wheel fell off #7
No but, he may get more responses if his question is legible.
   / wheel fell off #8
check tire pressure too! I had a front tire walk right off the rim last winter while plowing snow... was not fun to put back on.
   / wheel fell off #9
I don't have any college degrees and I could read it so I would imagine most everyone else could as well.
   / wheel fell off
the teacher is after us maybe forget a few things about school but after 50 something years its could be ok huh?
1995 Polar Tank Tanker Trailer (TITLE) (A50774)
1995 Polar Tank...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
Haulmaster Quick Hitch (A50515)
Haulmaster Quick...
John Deere 24" Backhoe Bucket (LOCAL TOWNSHIP) (A50774)
John Deere 24"...
Peterbilt 377 Semi-Truck (A52748)
Peterbilt 377...
(11) 8' Treated Posts (A50515)
(11) 8' Treated...
