Tires wheel base & ballast for tilling w/ TC40D
   / wheel base & ballast for tilling w/ TC40D #1
Tractorganic
Lower CT River Valley/US/Blue Moon Farm
NH/TC40D SS; BCS 850, Brush Mower, Sulky, 'Tiller, Chipper, Snow Blower; JD X570-48-A
I think I've got to pump the rimguard out of my R4 tires (currently at Dished In 78" position) and move them back to the Dished Out 68.3" wheel base so I can 1) decrease hard pan and 2) Limit tracks by pulling wheels in closer to the 55" length of the JD655 rototiller (largest) I can rent locally. I plan to siphon the rimguard by stationing and jacking the TC40D at a higher level than two 55 gallon drums, using garden hose w/ an Aqua Quick Fill air/liquid to the tire valve spud (with valve core removed) at 12 o'clock position, then rotate tire to 6 o'clock and siphon.
A) Am I going too far removing ballast to limit soil compaction? The combined ballast is 1200 lbs. I'll pump it back in next fall.
B) Do you think I need a pump in this siphon system (rimguard stinks)
C) Is it a waste of time and effort to move the tires? I'll also be renting a 72" Harley rake to further chop and level my field so at least that will smooth tire tracks but I'll be tracking behind the tiller. I love 'em at 78", great stabillity!
I can't afford to buy the right size implements right now. I'll be planting 8,000 sq. ft. of barley and white dutch clover and a 5,400 sq. ft. vegetable plot.
I haven't figured the soil compression of my tires but I used to worry about the foot prints I left behind my walk behind rototiller so it's a concern:(
Sorry for the humongous post but I'll be breaking ground in April or sooner:eek:
   / wheel base & ballast for tilling w/ TC40D #2
Most tillers can be offset to catch one side! As far as the ballast, the tiller comes though after the tractor so that will clean your compaction. Don't drain.
   / wheel base & ballast for tilling w/ TC40D #3
I wouldn't drain either. That is more effort than it is worth to me. An offset tiller would be perfect.
   / wheel base & ballast for tilling w/ TC40D #5
Seems like a lot of work just to rototiller. I would just borrow someone elses tractor but that's just me.
   / wheel base & ballast for tilling w/ TC40D #6
Why Drain the tires to change the offset? The weight can be managed if you work smart. Usign a hydraulic jack you can lift the tire just clear of the ground and work it off the hub, flip it and work it back on. this will take a little muscle but it is very achievable by the common man....
   / wheel base & ballast for tilling w/ TC40D #7
I suggest a plow and disk if you are breaking new ground. I'd be faster and you don't have to sweat the wheel track as most as I have never seen a farm disk less that 12'
Here's what I have planned:
1)Subsoil plowing
2)rototilling
3)Harley raking
4)Post hole digging
Chris
I'm not draining ballast just to facilitate tire manipulation, rather it's to decrease soil compaction ( by about 10 psi). I did just buy a new 3 ton hydr. jack and some nifty support jacks w/ fat bases to avoid tipping in the processed rock/sand in my driveway, as well as some steel plates to serve as leveling stations beneath each support. I had a tipping event a few weeks ago and the tractor almost crashed down:ashamed:. Separate post w/ pics. on jacking TC40D soon to follow.
Chris
I wish I could afford plow and disk sets. Can't rent 'em here. Only farmer I know who has 'em got to old to drive the rig the 5 miles over road to my place and I'm catching up steadily. Between the subsoiler (which I have ordered), the tiller and the harley rake (renting both) I should get nice tilthe, removal of some rocks and incorporation of the chop. I just don't want to turn it all to paste with my filled tires runin' way out.:eek:
Thanks,
Chris
KUBOTA L2650 TRACTOR (A51243)
KUBOTA L2650...
2011 Chevrolet Malibu Sedan (A50324)
2011 Chevrolet...
2015 FREIGHTLINER CASCADIA DAYCAB (A50854)
2015 FREIGHTLINER...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A51242)
2021 CATERPILLAR...
2012 Ford F-150 FX2 (A50323)
2012 Ford F-150...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
