Wheel adapter plates
   / Wheel adapter plates #1
Birdhunter
I have a Ford 2120 with front wheel assist, it now has turf tires I would like to get a set of AG tires for it. I understand that the wheel size is metric, so standard wheels will not fit. Wheels are only available though a dealer (expensive) Does anyone know if there are adapter plates available so standard wheels and tires could be used, and if so who makes them and how much?
   / Wheel adapter plates #2
Can't help wityh sources.. but do keep in mind the front to rear rolling circumference ratio of the new tires.
Soundguy
   / Wheel adapter plates #3
Wheeladapter.com
Keep in mind he is busy these days. I found someone local to make my spacers as Fred at wheeladapter.com was too busy to return my quote request and I didn't want to constantly pester him.
   / Wheel adapter plates #4
Try doing a search for used tractor parts or tractor salvage yards. One I know of is WKTP.com.
   / Wheel adapter plates #5
Wengers may be an option for used rims...
Soundguy
Thanks for the replys... and yes I understand the ratio's
   / Wheel adapter plates #7
Type Ford 2120 into the search at this site (on TBN) and it will bring up a lot of posts dealing with this same thing and suppliers.
How old of a tractor is it? If you could find some wheels that were close to the tire size, like off of a 1 ton truck, could you cut out the center of the wheel, weld in some plate, and redrill the bolt holes to fit your bolt pattern, then put ag tire on it and go. Now watch all the replies about balance issues, wobble issues, etc. start. Remember, this is a tractor, not a racecar.
1988 Kenworth W900B Dump Truck with 3406B CAT (A53473)
1988 Kenworth...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A53473)
2003 International...
1985 Miller Wildcat 350-D Welder (A51691)
1985 Miller...
2008 Polaris Sportsman 300 4x4 ATV (A51694)
2008 Polaris...
