What's your idle speed on 4110
   / What's your idle speed on 4110 #1
Cliff_Johns
Elite Member
Northern Illinois
JD 4110
What\'s your idle speed on 4110
For anyone with a JD 4110, what is your slow idle speed? Do you know what it's supposed to be?
Cliff
   / What's your idle speed on 4110 #2
Re: What\'s your idle speed on 4110
factory owners manual for my 2004 4115 says:
slow idle-
4110- 1000 +-25 RPM
4115- 950 +-25 RPM
fast idle-
2850 +-25 RPM for both
   / What's your idle speed on 4110 #3
My 4110 runs at just under 1,000 RPMs at the bottom of the range, just as roccon and the manual says. After starting, when it smooths out and the clatter dies, I bump it up to 1,200-1,400 to complete the warm-up. Fast idle is the rated engine speed that delivers a 540 PTO RPM. My eyes aren't that good any more, so all I can tell you is its just under 3,000 RPMs, again confirming roccon's quote.
OK, my idle is set too fast. Now I just have to figure out how to cut it down by 150 or so.
Cliff
   / What's your idle speed on 4110 #5
there should be a small screw or bolt with a jambnut on the injection pump. when you pull the throttle lever all the way back, this screw stops the idle arm. loosen the jamb nut and turn IN the screw until your idle is to spec. tighten the jamb nut.
</font><font color="blue" class="small">( there should be a small screw or bolt with a jambnut on the injection pump. when you pull the throttle lever all the way back, this screw stops the idle arm. loosen the jamb nut and turn IN the screw until your idle is to spec. tighten the jamb nut. )</font>
Hey thanks, when it gets up to double digits and I'm willing to go futz with the tractor outside, I'll do that.
Cliff
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
2019 Fecon BH74SS Hydraulic Mulcher High Flow Skid Steer Attachment (A51691)
2019 Fecon BH74SS...
2005 CATERPILLAR 321C LCR EXCAVATOR (A51246)
2005 CATERPILLAR...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
40' CONTAINER (A51244)
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
