What's your favorite big drain pan?
   / What's your favorite big drain pan? #1
BGigHarbor
GIg Harbor ish
.l5460, bcs 725, 852
I was at an AZ yesterday and picked up another drain pan. Flo Tool. Way flimsy and the cap doesn't catch on the threads.
So I am looking for another drain pan (or two) at least 5 gallons and some way to pour. Any favorites?
I am considering a Lisle 4.75 gallon.
   / What's your favorite big drain pan? #2
My brother in law gave me a plastic tub that he got with about 150# of molasses and mineral lick for his cows. It looks like it would hold 15-20 gallons. I plan to use that as a drain tub when I change the hydraulic fluid in my Kubota. A few years ago I bought something similar but a lot smaller at Lowes to plant some tomatoes in maybe 7 gallons size.
   / What's your favorite big drain pan? #3
TSC has quite an assortment of pails/buckets. I found one that holds 12 gallons for about $15. There is no 'pour" function but it would work great to drain the hydraulics without worrying about swapping containers. Getting the used fluid into something else would be a manual process.
   / What's your favorite big drain pan? #4
I did the hyd, on my DK45 a couple weeks ago (11gal) and was hard up for a pan big enough.
I took one of our old garbage cans (Rubermaid, 35 gal I think) cut about 2 thirds off of it with a razor knife, worked just fine for the hydro.
It has hand holds molded into the bottom of the can, when I picked it up of course it squished inward...it made it very nice to pour the oil out without the oil overflowing when it squished in, just make sure and leave it tall enough.
I did use a smaller pan for the finals.
I jacked the tractor up about four five inches to get the big pan underneath the transmission.
My other pan that I've had forever that I love is a stainless pan out of a butcher shop, rectangular shaped, holds close to 5 gallons.
   / What's your favorite big drain pan? #5
I used a plastic tub from Lowe's that is sold for concrete mixing. It has worked great for many things. The most recent was draining the trans/hyrdraulic fluid from my tractor. It has a large surface area to catch any stray drips, and it holds a lot of fluid. Unfortunately it is a two person job to pour the fluid into a transportable/recyclable container.
   / What's your favorite big drain pan? #6
I have three of these excellent pans and on big jobs often put the drain plug back in and put some in one or both of the other pans. That way I can handle it alone. Two people handling one pan does not work for me. I also have a dedicated anti freeze pan that I can rinse out before using in case the A/F has to go back in.
   / What's your favorite big drain pan? #7
Do you have a photo or a brand?
   / What's your favorite big drain pan? #8
I don't have a favorite but I do have 2 Lisle drain pans I bought from Advanceautoparts. I think they hold about 4 1/2 gallon and have a pour spout. Once I use the drain pans I pour them into empty 5 gallon jugs with screw on caps I get from work to dispose of them easily. Eventually I want to get a waste oil furnace to heat my shop since I go through a lot of used oil each year.
   / What's your favorite big drain pan? #9
Not sure I ever saw a name but maybe. There are two sizes of pans at Costco and I bought the big ones. if you need a brand name I'll go look. There are light, thinner ones and also heavier ones. I have the heavy.
   / What's your favorite big drain pan? #10
OK...I took the long way to get the mail. Here's a photo of each style of pan.
Here's the thin one.
And here's the thicker one
You can tell which is which by the thicker lip and thicker plastic.
Both will actually work fine.
And surprise, I think they are USA made.
IMT AF100 II (A45046)
2015 BUMPER PULL CENTRIFUGAL PUMP (A45333)
2015 BUMPER PULL...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A44571)
2023 Caterpillar...
ClubCar Electric Golf Cart (A42744)
ClubCar Electric...
2020 Chevrolet Traverse LS SUV (A42744)
2020 Chevrolet...
2023 Doosan DX27Z-7 Mini Excavator (A42742)
2023 Doosan...
