What's This?
   / What's This? #1
rvaitor
Platinum Member
Nashville, TN / Hickory, NC
Kioti DK55C
What\'s This?
I've got several curious pieces of eqmt. What is it used for and whether it is worth salvaging or fixing up.
Thought I would start this string and post some pictures.
Thanks to all for your help.
   / What's This? #2
Re: What\'s This?
My best guess is a part of a homemade 3 pt transplanter.
Save the 3 pt and make a carry-all platform or ballast box.
   / What's This?
Re: What\'s This?
Here is another shot. The owner of this piece also has a barrel full of concrete with a bar through it and a fitting at the top. I think this was used for ballast.
One thing my tractor has Cat II 3pt, are there sleeves or converters to allow Cat I implements to attach?
   / What's This? #4
Re: What\'s This?
Looking at both pictures, I'd say it was an old truck tire.
Cliff
   / What's This? #5
Re: What\'s This?
</font><font color="blue" class="small">( One thing my tractor has Cat II 3pt, are there sleeves or converters to allow Cat I implements to attach?)</font>
I know there are standard sleeves (bushings) for the draw pins going from Ø7/8" ID to Ø1-1/8"OD that you can buy about anywhere, as well as the top link pin bushing going from Ø3/4"ID to Ø1"OD.
My tractor has a Ø7/8" top link pin so I ended up turning down a Ø3/4"ID/Ø1"OD/ bushing in the lathe to make the OD Ø7/8". Those suckers are harder than H#@*!!!
   / What's This? #6
Re: What\'s This?
Could use the tire(s) to make leveling wheels for the boxblade if there are 2? And the 55 gal drums to make a bar-b-que. Then you could mount it to the carry-all making it portable for pic-nics anywhere you want. /forums/images/graemlins/grin.gif...just kidding about that part....but the 55 gal drums make great b-b-ques.
   / What's This? #7
Re: What\'s This?
RVatior, that is a tobaco transplanter. Hooked behind a tractor to transplant small seedlings. I rode one many hours when I was younger. 2 people sat in the seats and hand dropped seedlings into the open furrow and the roller at the back covered them. They were mostly used on a 3PH. but I have seen them trailer mounted. HTH. later, Nat
   / What's This? #8
Re: What\'s This?
rviator,
I thought the same thing about a transplanter, but, if those shield-looking things rotate, it could be something called a border-checker.
Border-checkers are used to close borders for irrigation where borders cross like at right angles.
<font color="brown">A Border Disk</font> throws soil together to form a berm to control irrigation water. In an application like an orhard where you have criss-crossing borders leaves the sections compromised where they will leak water. The border-checker is dragged along after the border disk to close where the disks cut through the border at the right angles. (believe me, you don't want to do that by hand!) /forums/images/graemlins/wink.gif
But, that's just my guess. /forums/images/graemlins/crazy.gif
   / What's This?
Re: What\'s This?
</font><font color="blue" class="small">( RVatior, that is a tobaco transplanter. Hooked behind a tractor to transplant small seedlings. I rode one many hours when I was younger. 2 people sat in the seats and hand dropped seedlings into the open furrow and the roller at the back covered them. They were mostly used on a 3PH. but I have seen them trailer mounted. HTH. later, Nat )</font>
That makes sense to me -- BTW - that piece of equipment is in NC/Hickory area, so maybe it was something used in that area. I kinda thought those were seats or could be. It was probably purchased/used in the 60s.
   / What's This? #10
Re: What\'s This?
Tobacco transplanter? Come on, that is obviously a 3-pt tire-track eliminator for obscuring evidence when leaving the scene of a late-night federally-protected waterland modification project. /forums/images/graemlins/shocked.gif
How can I be wrong when I used 4 hyphens in one sentence?
Dennis
2021 Kubota SVL97-2HC Compact Track Loader (A50657)
2021 Kubota...
PALLET OF BRAKE AND AXLE PARTS (A50854)
PALLET OF BRAKE...
John Deere Ztrak M665 60in Zero Turn Mower (A48082)
John Deere Ztrak...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A48081)
2015 Chevrolet...
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A48081)
2001 Sterling...
2012 FREIGHTLINER CASCADIA (A50854)
2012 FREIGHTLINER...
