What's this CK25 dash indicator?
   / What's this CK25 dash indicator? #1
Greenecho
Newman Lake, WA
CK25HST
I seem to have a dash indicator that's been turning on & off lately. It's not in the manual that I can find. It's located directly below the high-beam indicator. It's a circle with zig-zag lines through it. Similar to a resistor symbol.
It seem to come on when the tractor is cold and when I move forward with the tractor under slightly hard acceleration. The fluid levels look good in everything.
Anyone know what this symbol is for?
Steve
   / What's this CK25 dash indicator? #2
Glow Plug Indicator Light?
Nope..not it. Not the oil pressure or charge indicator or parking brake, or glow plugs, or for that matter - in the manual. The only indicator on the dash that's not explained.
   / What's this CK25 dash indicator? #4
Level of fluid in the coolant reservoir. Add a cup or so. I have had to do this once after about 350 hours of operation.
I wondered if that couldn't be it. I didn't notice any sensor on the reservoir. Probably missed it.
I'll give it a try.
   / What's this CK25 dash indicator? #6
My oil pressure light was winking on and off around 49 hrs, then came on steady at 56hrs. At the svc check the plug was found to be loose, you may want to check the connections...........
RD
   / What's this CK25 dash indicator? #7
Greenecho, the sensor is on the bottom of the resi.
BTI
2014 Chevrolet Express Cargo Van (A50323)
2014 Chevrolet...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
M & W Little Red Wagon (A50515)
M & W Little Red...
2013 Ford F350 Service Truck (A50515)
2013 Ford F350...
Wolverine Quick Attach 68" Bucket (A50515)
Wolverine Quick...
1999 Case 90XT Skidloader (RUNS) (A50774)
1999 Case 90XT...
