What's the value of this wood splitter?
   / What's the value of this wood splitter? #1
tillboy2001
We have an older 24 ton wood splitter that looks really close to this: Amazon.com: 24-Ton Log Splitter with 9 HP Honda Engine: Home Improvement
The one we have is setup like that where it's on a small frame with wheels, it's horizontal (not sure if it can be tilted vertical) and it has a 8HP Briggs engine on it. The splitter itself works well but I think the engine needs to be tuned up. It's rarely used.
Anyway, before I put it on ebay or something, I have no idea what a fair price is. What do you think? Assume that it works but may need a good tune up on the engine. What would your thoughts be on the asking price?
   / What's the value of this wood splitter? #2
There isn't much consistency on used equipment pricing. I would look to see what's available in your area for other used splitters (ebay, CL, etc).
Most of what I've found locally is $750-900 apparently regardless of size or age. Also $500 or so for a three point style (no engine).
-rus-
   / What's the value of this wood splitter? #3
I live in Indiana just a few miles from the border. You should get $550 for it unless some idiots get in a bidding war and it sells for more than a new one. Right now my TSC has 10% off anything over $100 so it makes that splitter $899 new. The one in the picture has a Honda so its in a completely different league than a BS powered unit and worth $300 more.
Chris
Thanks. I'll do some checking and see if I can find anything similar for sale. Just need some ballpark figure to start with. We're not too concerned with making a killing off of it, just not giving it away for nothing and then learning later it was really worth a lot more.
   / What's the value of this wood splitter? #5
I would start the auction at $300 to get folks hooked then set a $550 reserve price. I have a feeling you will get closer to $700 using EBAY because of the IDIOTS on there. I just sold some stuff for more than you can go to Walmart and get it new. Its like a gambling addition. They just cant stop bidding.
Chris
   / What's the value of this wood splitter? #6
I agree with D.P., its worth around $500, maybe a little more if you get it running good and if it goes vertical also. Usually the bigger splitters go vertical.
1261 (A50490)
1261 (A50490)
2025 K1912 UNUSED Metal Livestock Shed (A53117)
2025 K1912 UNUSED...
Toro Workman 175 Sprayer Cart (A50324)
Toro Workman 175...
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A53426)
2007 PETERBILT 379...
Light Tower (A52377)
DRIVE UP RAMPS (A53843)
DRIVE UP RAMPS...
