Price Check WHATS THE GOIN RATE
   / WHATS THE GOIN RATE #1
DSL DOC
Howdy guys, dsl doc back in the saddle, need to know i have mid 80's gravely pro16g now the only info i can find anywhere says its an 18 horse not 16, see this has a flat air box and is "force fed" air from the blower housing as i have a bunch of pix for any serious emailers the carb, fuel pump are being replaced as we speak :thumbsup: i do have the serial numbers Gravely S/N 00594840 and right under that another tag on frame same location 42149. the deck S/N is well i have it somewhere. it wil start run, can and will do compression test in front of buyer fluids are all new good deck belt good deck ujoints this tractor is clean. it needs paint but body is darn near flawless. it does have two probs but still fires up and mows the deck pto is allways on, one of you geniuses that want to tear it down and replace pto clutch assy, that would be the proper repair. the other issue is the govenor might need new springs to carb i might check into that as weell or help fix it. the springs are bent slightly. otherwise hop on and mow i am also putting new blades on the deck. the valves look good from having the intake off. shes a SOLID IRON TANK have to move this thing in approx 2weeks today obviously is 5-16-10
:D:D:D:D:D:D:D:D:D:D
jim "dsldoc"
jcornelison12345@charter.net
ill give this tractor away for 600 bucks need money now divorce:(
   / WHATS THE GOIN RATE #4
Good luck. $600 is a good price for it, because I understand splitting the case to replace the PTO clutch is a major undertaking.
ITS NEAR GREENVILLE, SC and ill go 400 no carb or fuel pump rebuild
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52577)
2013 UTILITY VS2RA...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2014 Toro Workman HD Utility Cart (A51691)
2014 Toro Workman...
2024 Icon I40L Electric Cart (A50324)
2024 Icon I40L...
2003 FREIGHTLINER CLASSIC XL  SLEEPER (A52141)
2003 FREIGHTLINER...
