dirtycat
Hello i am new here and i own a 08 caterpillar 303c cr excavator and was wondering what's the best oil to use.
Some Cat equipment may have operational characteristics that need a more viscous oil, but I did not remember your mini being in that class. Cat did pay dealers warranty to replace factory fill HYDO 10 with 15W-40 but only in areas where ambients regularly topped 104. 15W-40 engine oil makes a great hydraulic oil but at 3 times the cost (factory pricing). The alternate oil I suggested is much less expensive and is roughly equivalent to a 10W-30. You can pick up a similar oil from Exxon-Mobil - Mobilube 424. You will find that there are many oils stating they are equivalent but if it's cheap, it likely does not have an equivalent additive package and although it passes the basic tests to meet spec, are you willing to bet the life of your machine. You can read up on the oils and machine requirements at cat.com.The hotest it gets here is 90 degrees and the coldest is around 20 degrees. I was told to use a 15-40 weight motor oil.
