What's the best loader valve?
   / What's the best loader valve? #1
Roger66
Shelton
2017 Mahindra 1526, John Deere LX255
I have a Mahindra 1526. It's a great tractor. One thing that does not work so well is the loader valve. Overall it works and holds properly, but fine adjustments are tricky, especially trying to lower a heavy load slowly and smoothly. Also to try and slowly and precisely curl it up. It's been like this since new, so it's not worn out, but perhaps a cheap valve? For normal loader dirt work it's not at all an issue, but for precise pallet fork work it's a challenge. I'm wondering if I should just swap out the loader valve with a higher quality valve. Any suggestions on who makes a premium quality loader valve? My tractor flows 7.5 GPM. I can fabricate or modify anything necessary to mate a different better valve to this machine. Any suggestions?
Thanks!
   / What's the best loader valve? #2
You could consider installing an adjustable flow control valve($25) to limit GPM flow to FEL control valve. I installed a similar valve on a Kubota M4900 FEL so 1000# rd bales could be controlled easier & bales not drop so fast.
   / What's the best loader valve? #3
I don't know if just changing the valve will help. I've used some tractors that were smooth as silk and others that were really hard to operate. All name brand equipment, some models within one brand are great, other models are not. So I'm guessing there's a lot more to it than just picking the right valve otherwise manufacturers would always get it right.
I have some of these flow control valves in my hydraulics stash and I've been considering trying that tactic. I was just wondering if there a premium valve out there that would just be nicer all around. I don't mind spending some $$ if it resolves this annoyance. I have some Prince SV12 sections in my stash, could use them and add a joystick kit just wondering if there is a better option. Why is it all tractors I've used have (IMO) poor valves, but a mini excavator can be controlled so much more precisely?
   / What's the best loader valve? #5
because they use a different type of valve that uses pilot valves and electric solenoids. drop the rpm to idle if you need slower control, or add a restrictor like mentioned.
   / What's the best loader valve? #6
I'd say that TX Jim made an excellent suggestion, slowing the flow will reduce the speed without reducing the pressure.
You can go adjustable (as he showed) or fixed for even cheaper.
Heck I even DIY'd once by welding a fitting shut and followed by drilling a tiny hole.
   / What's the best loader valve? #7
A good quality valve would benefit your loader control but the problem is finding one with individual load checks, float, power beyond that also has excellent metering is a challenge. To really get good repeatable control the valve spool should also have pressure compensation for each spool and have asymmetrical spool so that flow paths are matched to cylinder ratios .
Flow control is a fix that will help at a much lower cost.
I'm going to try changing the valve to a Prince LVT Loader Valve 10GPM LVT1GR5AB7. I believe this is worth a try. I'll likely also add the adjustable flow control valves as well to fine tune it. I'll post back if this was worthwhile or a waste of money once I get it plumed in. Again if all you were doing is dirt work or gravel work the stock valve is totally fine, but when you have a precarious load on a pallet with a non self leveling loader, you need precise control.
   / What's the best loader valve? #9
I know exactly what you mean, but don't know why some valves are that way and others are not. It might even be a deliberate difference rather than quality - more about that below.. .
Like you, I've wondered if it could have to do with the way the way the valves are machined. Here is what I do know: Our Kubota M59 TLB has the most accurate and precise loader and backhoe valves I've ever tried. Remarkable control. You could peel an apple with those controls. When stacking rocks for a stone wall I can gently move the bucket up against a 500 lb rock and then scoot it ever so little in any direction - maybe a quarter of in inch at a time .... and with perfect control. Both my wife and I have no problem working in the garden with that TLB's accurate bucket.
On the other hand, our larger JD310SG certainly didn't scrimp on quality anywhere. New, it cost twice what the Kubota TLB did. But it has loader and backhoe control valves on both ends that just will not make fine movements - although I will say the the loader is somewhat more accurate than the hoe. Maybe the valves are worn, but I don't think so. Moving the lever ever so slightly, the backhoe bucket doesn't move at all, and then suddenly moves very rapidly a few inches. It has the same width bucket as the Kubota, but we wouldn't dream of using it in the garden. I won't let anyone stand within ten feet of the backhoe when it is being used.
Here's an odd thing though: An old timer operated our JD310SG doing a job for us one day and without being asked he commented later that he liked that old machine because it had the optional "long-throw controls" that were designed for speed rather than small movement accuracy. I've never heard that before and have wondered since then if he knew what he was talking about or if it was just babble & opinion.
Bottom line is I don't know the answer to your question either. If the difference is something like control valve quality, I don't even know what to ask for. But amglad you asked the question and will surely watch this thread to learn more.
rScotty
I wouldn't be surprised if the speed vs accuracy thing might come into play. This tractor is designed for bucket work not fork work and it does bucket work just fine. Typically for bucket work you want speed. The part that does not make sense is you would think the long throw controls would be more accurate and the short throw controls would be faster. Time will tell if the prince valve is any better. It's kind of a shot in the dark, but as they say you fail at 100% of the things you don't try. If I don't like the Prince valve I may just try another.
Ryobi Sliding Compound Miter Saw (A44391)
Ryobi Sliding...
2009 Honda Pilot AWD SUV (A42744)
2009 Honda Pilot...
Bradco 42in. Skid Steer Pallet Forks (A39855)
Bradco 42in. Skid...
2019 Ford F-150 XL (A44500)
2019 Ford F-150 XL...
2021 Chevrolet Tahoe FL SUV (A42744)
2021 Chevrolet...
2016 SkyTrak 8042 8K Forklift (A42742)
2016 SkyTrak 8042...
