What's my 2009 CK35 worth?
   / What's my 2009 CK35 worth? #1
Kilo69
Coldstream Nova Scotia Canada
Kioti CK35 HST
So,
Looking at upsizing to a DK50 HST, mainly to get the next step up FEL as it's rated at 2700lbs vs 1100lbs my current CK35 has. ALso the 50hp makes running a baler and discs a better option since I want to start haying my own fields.
So here's the details on the current beast
2009 with 290hrs
CK35 HST with FEL and 60" Bucket
Industrial tires (R4 I think)
I've owned it since 2hrs on the clock, it's been shedded it's whole life and all maintenance done at the intervals in the books. Only damage is to the PTO cover that got bent by the plow first time I hooked it up. (self clearance plow grrr). Other than that it's hard to tell it's been worked much at all. Clean and ready to work.
I'm in Canada so it'll be a little higher than the US folks but I can do the math so feel free to comment in USD. I'm just looking to get a feel before I talk to the dealer on what he'd offer on trade for a new DK50SE HST.
THanks for reading/commenting!
   / What's my 2009 CK35 worth? #2
$12,500 - $15,000 US dollars.
   / What's my 2009 CK35 worth? #3
I'd guess $13.5K U.S. or so.
   / What's my 2009 CK35 worth? #5
$9,600 to $10,900 per HotLine Compact Tractor guide Volume XII (2014).
Add for FEL value.
Factor in condition, hours and your R4 tires.
I hope this helps,
Donald
   / What's my 2009 CK35 worth? #6
I picked up an LS that size with Back Hoe for 13,000 US, so I am thinking 10K US is more realistic,
   / What's my 2009 CK35 worth? #7
I'd keep it before I'd consider 10K. It's pretty much a new tractor, and the replacement is like $17K.
   / What's my 2009 CK35 worth? #8
I am going the other direction.. I think it is worth 13,500 to 14,000 to a private buyer, In other words, not traded in to a dealer.
A lot of that is in my minds eye this is a very clean tractor and looks near new. If it looks bad, then not that much.. You would be surprised what touch up paint and cleanup will mean in the end price. I would fix the dent in the PTO cover, and repaint it. Or get a new one..You don't want anything for a buyer to "knock".
   / What's my 2009 CK35 worth? #9
Clean tier 3 CK35 with 290 hours for 10k:laughing: That would be a heck of a score for someone;)
If it is looking close to new, I'd replace the pto cover and not take less than 13k.
   / What's my 2009 CK35 worth? #10
Let us know what you get for it. It is a tough market out there.
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A53472)
Kubota BX2680...
2011 GMC SIERRA 2500HD (INOPERABLE) (A52472)
2011 GMC SIERRA...
2025 New/Unused Wolverine 3 Point Quick Hitch (A51573)
2025 New/Unused...
Simpson 3400 PSI Pressure Washer (A51573)
Simpson 3400 PSI...
2012 UNVERFERTH 10-INCH FRONT WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
