What's killing my pine trees?
/ What's killing my pine trees? #1
dbdartman
Platinum Member
central New Jersey (No. Burlco)
JD4400
Something growing on five of my pines has killed a couple already & is hurting others. Never saw anything like this before & my research turned up nothing (which really surprised me). Anyone know what this is & better yet how to fix it?
Thanx,
DB
~edit~ Added pix
/ What's killing my pine trees? #2
Im a forester, yet i live here in the south and am better at forest pests vs ornamentals trees and pests. But first look with out reasearching is tip moths, yet they usually dont kill a tre just the top and cause multiple leaders to then grow. Not sure i can tell the pine or not, is that virginia pine or white pine? Lokking at the bark i would have to say white pine, but the branhing dosent look right. This must be a more norhtern species we dont have here , red pine with out looking i have no idea what this looks like.
I would say those find out what those casings are from and you have your answer. Spray the tree with an insecticied as well as the others to try and save it. Go to , i think, bugwood.net or maybe org. Its the forest service site and there are many pics of pests and damage they create. I dont have time now as im at work.
Thanx, I'm in NJ & yes it's a white pine. They've been there for 4 years.
I'll check that site, thanx!
/ What's killing my pine trees? #6
Sorry for the short reply.
Those are bagworms. The worm makes a shell out of silk and sticks pine needles to it. It looks like a limp small pinecone. However, if you look really close, the worms head, mouth and a few arms are sticking out of it and it hangs upside down from the branches as they munch along. They can devastate a tree in short order.
Google bagworm and look for control methods. I had to get a liquid insecticide, I believe it was Sevin, and spray the tree. Still, I lost a good chunk of the bottom of my tree that will never come back.
If you see a few of these one year, you will see many, many more the next. By year three, the tree is toast. So, if you have these weird little pinecones, poke them and watch them start squirming. Pinecones are not supposed to squirm! Kill them now or you are doomed. :cool:
/ What's killing my pine trees? #8
I had these on 5 pines in southern Indiana for a few years. A couple of applications of a liquid insecticide sprayed from the hose fixed the problem. All but one of the trees lived.
/ What's killing my pine trees? #9
i had same problem with my pine trees 2 yrs ago it was a worm. i went lo lowes they have a book in the pesticide department u can look at i found that worm in the book then it tells u wat pectiside to buy, i bought it sprayed it on my trees couple of times they havent come back yet.
/ What's killing my pine trees? #10
For while I was losing couple Colorado blue spruces damage started at top by turn brown,lot folks call them spruce bugs..cut the tree burn it killing eggs,so far it has work.
/ What's killing my pine trees? #11
i dont see bagworms often, i was thinking tent catipillars but those pod things look nothing like the tent the tent pillers make. Told ya i dont know my yard tree pests.
/ What's killing my pine trees? #12
You might try spraying with a heavy dorment oil. I will coat the insect and bag and stop it's ability to breath as insects breathe through holes in their exoskelitin(sp).
/ What's killing my pine trees? #13
Bagworms! That's a new one on me and I have been a forester since '75, but only in the west and I see these critters don't go west of Nebraska. Learn something every day...
/ What's killing my pine trees? #14
If I knew more about tree names I could tell you which ones are surviving and which ones are dying but all I can say is that certain species of pines are all turning brown and dying around here. And you're not too far away.
Looks like some kind of blight to my untrained eye. One guy near me kept replacing the dying ones with ones of the same type that would just die the next year. He switched to a different species last year and they're doing good.
I've been watching it spread.... it was miles from my house three/four years ago. Now the ones on my road are dying out. You have no idea how happy I am to have the "good" species on my property.
/ What's killing my pine trees? #15
Bagworm it is... and I seem to have it bad. :(
Thank you!
You have to spray the tree now, while they are active. Once the little bugger pupates inside its fortress the insecticide will be less effective. It will lay over until the moth hatches and lays more eggs. I used a pump up tank sprayer, stood on a ladder and was able to do my 35' blue spruce. The liquid sevin worked and I only had a few the next year and sprayed them again. I found just a few on other pine trees, but that spruce had thousands. I lost a 6' x 6' patch at the bottom of the tree that will never come back. Fortunately, I figured it out and killed them before they got the whole tree, but the tree looks ugly with that big chunk missing from on the street side. We may end up cutting it down anyway. :(
/ What's killing my pine trees? #16
If these are newly planted trees its probly cause there planting them at the wrong time of year. Its to hot and not raining enought to transplant pines. Pines need to be planted in the late fall to winter, around my part here in SC i would not plant anylater personally than march and that really is to late. IN NJ you may get away into april? Pines also suffer from several bark beetles and other things. The uneducated call them all pine beetles. The worst and one that will spread like wildfire is The spp. pine beetle, or southern pine beetle or western pine beetle. It bores into the bark and lays eggs in cambium and when the larvae hatch they feed in the cambium layer of the tree then fly away to attack other adjacent trees as this cysle repeats your trees die. The beetle is the indirect killer, they have a fungus that they bring with them which then is introduced to the tree and it slowly chokes it off, by stopping watter frow and nutriet flow from the roots to the needles. These are identifed by pitch tubes or resin mounds on the tree truck up to a height of around 20 feet. They look like way globs and have a hole the size or smaller than a grain of rice, which is the size of the beetle. If you take the bark off a tree they are identified by the "S" shaped galleries that the larvae leave in the cambium layer. The S. pine beetle attacks all souther pine species some more than others with longleaf and slash pines being most resistant. They also attacked stressed trees first, wether it be from root compaction fire damage, drought, to wet, lightinig strike, other insect attacts like Ipps (see below) to much competition. The species that they effect all southern pines, including sand pine, virginia, pine Loblolly pine shortleaf pine , longleaf pine, slash pine, sonderegger pine, maybe pitch pine. And possibly others but this is all i would eveer see them in. These will sometimes go on for years just spreading from a central point like cancer till they either are controlled by natural bug preditors and or the stress is releived like if in drought you get rain. Or they hit a nautural buffer like a lake, highway, or man clearcuts them infront of the advance. A "hot" spot can move at the pace of a hundred feet or so in all directions from the center. Pine beetles are cyclical and go in cycles of 5-7 years between the epidemic years, 2001 was our last epidemic year around here. Im holding my breath wating on the little suckers. They were rampet killing trees that usually are not touched by them.
The Western pine beetle in the last 5 years has decimated the western forrest from what i have seen and been tolk by a friend who elkhuts CO. Says every pine you see there is dead.
The other less destructfull ipps engraver beetle also attacks southern pines. All the same species. Similar invasion technique but higher on the tree, pitch tubes will be higher on the bole (tree trunk in laymens terms) These are more random of progression sometimes 3 trees sometimes 300 trees. They will stop on their own usually with little damage unlike SPB (southern pine beetle). They hit a stand more like a shotgun with smaller spots peppered acrosss an area unlike the cancer like spread of SPB. Ips trees are identified by flagging (dieing) of upper branches and top dieback first. These are not as worry some so im not going to cover them as much. To control you can just cut the infected trees a buffer is really not needed but most will put a tiny one on them.
No this is not a WIKI quote or pirated from some paper or university site. I am a forester so i know more about them than the normal landowner, this is just common knowledge amoung the profession. I have left many things out about both but they really are irrelevant in this discussion and this is already a long post.
Nate
USACE Resident Forester
BS Clemson University
MFR Clemson University
/ What's killing my pine trees? #17
Even though im a forester who makes a living off of pine, i would not plant one within 120 feet of my house or keep one within that distance. They have bad habits of snapping off or blowing over. I dont want one cutting my house in two.
/ What's killing my pine trees? #18
So sorry to hear about the worse conditions of the trees.
But I wonder how could insects like bag worms or caterpillars harm pine trees...
/ What's killing my pine trees? #19
The bagworms crawl along the branches and eat EVERYTHING THAT IS GREEN. All of it!
/ What's killing my pine trees? #20
Looks like the bag worms I have had in the past. I spray with Ortho Systemic bug spary and it kills them pretty quick.
Dan
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
66'' BUCKET WITH TEETH (A61567)
66'' BUCKET WITH...
2016 Ram ProMaster 2500 Cargo Van (A61573)
2016 Ram ProMaster...
Transfer tank (A61567)
3PT FENCE ROW SPRAYER (A63291)
3PT FENCE ROW...
2009 Ford F550 Flatbed w/ Lift Gate (A62613)
2009 Ford F550...
