What's in your Cargo Container?
   / What's in your Cargo Container? #1
Mudfarmer
Western Washington
JD 3005, Kubota B2710, Kubota B2650 (sold the ford 1700 and kubota B7100)
Got my cargo container organized for spring. I have it situated on my remote tree farm so that I can securly store my Kubiota B2710, attachments, and tools. This container is a 20 foot high-cube ("high cubic foot volume" - nine and a half feet tall vs the usual 8 foot). I had delivered in a rainstorm last winter. I had to call the cat guy to pull the delivery truck up the hill. Photos show what it will store. I usually like to back the tractor in, just in case I have to jump start it sometime, but with the addition of a new bush hog I need to head the tractor in and put the FEL on top of the mower. Of course if I took off the log splitter I could back in. Note the Harbor Freight furniture dollies under the implements. Makes for adjusting their postions in small space quite easy. Got a good lock and had the vender weld on a lock box to protect against bolt cutters. I'd like to see pictures of others for ideas.
Mf
   / What's in your Cargo Container? #2
Looks great. I thought about doing the same thing at our property, but then decided to bite the bullet and build a pole barn. Still like the idea of those containers though! Looking forward to seeing other pictures/ideas as well.
For a remote place I think it is harder to break into a cargo container than a pole building sonce the steel walls are thicker. I could envision somone powersawing into the pole barn I have (noisy, but effective), but they would need more than that to get into the container - more like a cutting torch.
Mf
   / What's in your Cargo Container? #4
Do they have vents in them? If not I would suggest cutting one in somewhere so that they can breath, otherwise they will condensate.
   / What's in your Cargo Container? #5
We use ours for square bale storage. Works great. If stacked correctly, we get 334 bales in 40 ft
   / What's in your Cargo Container? #6
Mf
Since you are from this area. What does a container like that cost and who did you get it from?
   / What's in your Cargo Container? #7
Its a 40ft cluttered mess..I know.
Not really a problem, don't know why. Certainly not like my pole barn which rains inside on a cold day. Since icondensation is not a problem cargo movers have, I guess it is magic. (Maybe it's because there is no moisture coming up from below since they are tight all around).
Mf
Aztec Container in Rochester. They have a website you can google. $3500 delivered (plus a couple hundred for the cat guy to get the truck up the hill), would have been $3000 or so with out the paint job. Of note, forty footers are only hundreds more than 20 footers. I didn't have room for the long one, but would have liked to have the space.
Mf
2023 Maxx-D TDX Tandem Dual Flatbed Tilt Trailer (A55218)
2023 Maxx-D TDX...
2018 MACK CHU613 DAYCAB (INNOPERABLE) (A53843)
2018 MACK CHU613...
2019 HYUNDAI VC2530152-JS DRY VAN TRAILER (A54607)
2019 HYUNDAI...
2017 Ford F-550 Crew Cab Enclosed Service Truck with Liftgate (A53422)
2017 Ford F-550...
UNUSED DIGGIT 20'X30' METAL GARAGE CARPORT SHED (A54757)
UNUSED DIGGIT...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
