whats difference between 2720 and 2032R
   / whats difference between 2720 and 2032R #1
feasant
Bronze Member
MT
JD 2720, JD480b, Case 310G, Cat #11
hi,
whats the difference between a 2720 and a 2032R other than years made?
tractor data lists them with the same engine.
does the newer ones have emissions control?
there are 2 used ones i'm looking at.
thanks
   / whats difference between 2720 and 2032R #2
The pre-2017 2032's and the older 2720 are the same machines with different badging, the 2017 2032's are a completely new design (similar to the 1-series), and yes they have a DPF system.
Why JD duplicated the model number from 2016 to 2017 is anyones guess, buy boy is it causing confusion!
   / whats difference between 2720 and 2032R #3
Wait - are you suggesting ANY of Deere model names make sense? :)
   / whats difference between 2720 and 2032R #4
Lol...so true in years past, but they actually do now. The first number is the frame/series/chassis size, the next three are the horsepower rating, and the letter is the trim level.
   / whats difference between 2720 and 2032R #5
kennyd is right, they are practically the same machine. But actually, JD made a few subtle changes to the pre-2017 2032R. The 2032R has RIO on the PTO which the 2720 does not. Also, on the 2032R they added two little metal guards to the left and right of the radiator that are not on the 2720 (still not sure what the guards are supposed to do). The 2032R has a green fuel cap and the 2720 is black. ( :) )
There are probably some other changes if you dive into the parts list. RIO on the 2032R is the most significant difference IMHO.
   / whats difference between 2720 and 2032R #6
This!!
Quick Attach Skid Steer Quick Claw Grapple Industrial Grapple Rake (A52748)
Quick Attach Skid...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50323)
2016 Big Tex 14ft...
V8 Mercruiser Boat Motor (A50121)
V8 Mercruiser Boat...
2007 Hino 268 Truck, VIN # 5PVNE8JVX72S50442 (A51572)
2007 Hino 268...
2009 Ford E-350 Cargo Van (A50323)
2009 Ford E-350...
John Deere 6120E (A50323)
John Deere 6120E...
