What would u make with this?
   / What would u make with this? #1
Big Bri
Platinum Member
Kubota MX5100
This is a carpet boom pole that I picked this up about 4 years ago (for free) and don't know what to do with it, if you have an idea please let me know otherwise i'll take it to the scrap yard. it weighs over 100 lbs and is solid steel and is about 12 to 14 feet long.
Thank for any suggestions
Brian
   / What would u make with this? #2
A fancy hydraulically operated gate to keep the rif raff out. The kind you see in front of federal buildings that go up and down out of the ground...
Great idea but there nothing that important at the house that anyone would want. . . except the bota:D
   / What would u make with this? #4
I'd enbed one end in a concrete filled tire so it is sticking straight up. Then hang a horseshoe shaped crosspiece on it (center of gravity below the point) and make a fancy windvane for the front lawn....Mount solar powered lights on it for effect
   / What would u make with this? #5
Same as pat32rf but after planting it, use the pole as the trunk of your outdoor Christmas tree. Run strands of lights from the tip to the ground all around. :)
   / What would u make with this? #6
Maybe a hay spear?
Cut in half and make forks for the loader?
   / What would u make with this? #7
Hay spear, Hook on bucket fork rod , counter weight, 3point log/bale fork. tons of things.
   / What would u make with this? #8
Got carpet?:rolleyes:
   / What would u make with this? #9
About 5 yrs ago or more I would have cut it in to and made my bale spike out of it. Since I've already done that I might go ahead and do that again and sell it on Craigslist or to someone you know.
Jay
   / What would u make with this? #10
what ever you think of or need it for you will discover the project with in 2 weeks of taking it to the scrap yard.
2007 Ford F-250 Crew Cab Pickup Truck (A51692)
2007 Ford F-250...
2021 JOHN DEERE HX14 (A53084)
2021 JOHN DEERE...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
550 Tubes Grease Cartridges (A53117)
550 Tubes Grease...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
