what will 10hp more in a tractor do?? will it give it my backhoe strengh??
   / what will 10hp more in a tractor do?? will it give it my backhoe strengh?? #1
yukonhunter
leroy ny
John deere 5100m, mf1643 cab and kubota bx2370woods bb720x land pride disc and reverse tiller
Its down to the wire between the mx5100 or the jd 4520...its a 5000 dollar difference both have loaders, jd has the 400cx loader both have backhoes jd is 60hp Kubota has 52hp ..jd has a third valve in the rear..I'm stuck on if its worth it. I mostly due timber work with some food plot work, will the extra hp help with backhoe digging?? Please help
   / what will 10hp more in a tractor do?? will it give it my backhoe strengh?? #2
Taking a quick look at Tractordata.com, it appears the horsepower is actually about the same. However, the John Deere apparently is considerably heavier. I think that might help more on the digging than horsepower.
   / what will 10hp more in a tractor do?? will it give it my backhoe strengh?? #3
Size of backhoe has to do with tractor frame size and weight. Unless you gain a larger frame size, the backhoes are going to be rated the same. For instance nearly all if not all tractors have several models with varied HP on the engine but the frame size is the same therefore the backhoe would be the same for all these models.
If the JD is larger physically in size, then it likely has a bigger back hoe with higher capacities. Check the specs for each of them with regards to digging depth, breakout forces for bucket and dipper, lift capacities etc and you will readily see which one has the better hoe.
   / what will 10hp more in a tractor do?? will it give it my backhoe strengh?? #4
If it's Pto powered hoe than no it won't..if it uses the tractors hydraulic system than the tractor with the higher pump gpm will give you more speed and performance at the hoe but not neccesarily more digging power,that's determined by the backhoe and pressure relief settings on the tractor.
   / what will 10hp more in a tractor do?? will it give it my backhoe strengh?? #5
Great point RD. My Kubota hoe has it's own pto pump. Love that I do not play w/ hoses. Also, a comment on the savings. for me I love my Orange. I assume Kubota is cheaper here... right. ;-) Hauling around a heavy backhow on the 3pt is not something I do for long periods. Mine is 900Lbs. Gas consumption goes thru the roof! Less weight can be a good thing - Depending. You'll make the right choice for you.
btw/ What cool timber accessories can you get for $5K? I love this site.
Tractor Attachments | 3 Point Tractor Attachments | Tractor Loader Attachments
The gang here will help you spend your money. :) I am envious of ya! Enjoy which ever you do buy! CG
It uses the hydrologic system..Kenny I think you looked at the old 4520..the new ones are way different, I made that mistake at first too
Yeah Kubota is cheaper
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
Caterpillar 420F2 IT (A53314)
Caterpillar 420F2...
Ox Bodies 13.5ft 12-14Yd Dump Box Truck Body (A52377)
Ox Bodies 13.5ft...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
2020 CHEVROLET SILVERADO TRUCK (A51406)
2020 CHEVROLET...
2010 Ford F-750 Stellar 10621 10,000LB 5 Ton Crane Mechanics Truck (A51692)
2010 Ford F-750...
