Oil & Fuel What weight of oil??
   / What weight of oil?? #1
jerrykeith
John Deere 316
I have 8 hours on my X530. I was wondering about what weight of oil to use? I live in Southern Indiana. I mainly use it for mowing. But I will haul fire wood in the winter. In the winter it is in a heated garage, so there will be no cold starts..
   / What weight of oil?? #2
The owner's manual says 10w30 for the midwest. That's what I'm running in my X534 over here in Kansas. Did you see the discount coupon on JDParts for the maintenance kit? It's early for the spark plugs and filters but I doubt they will be cheaper in the future.
Enjoy your new machine, Alan
   / What weight of oil?? #3
Normally we use 15w 40 as the standard oil. I would think about a 5 or 10 w 30 oil for winter-summer use to add winter starting and summer protection to 130 deg field temps.
I also thank that 8 hr is too soon, most service is done at the 50 hr mark.
Thanks...How do I get the coupon? Every little bit helps..
   / What weight of oil?? #5
As you know 8 hours is the recommended 1st oil change due to contamination from the engine break in. For summer use the manual calls for either 15-40 or 10-40. Both give the same high temp protection, but the 10-40 will be kinder to your engine on startup. The quicker that oil gets circulating the better.
(I just did the 1st oil change on my X530 as well and love the tractor!)
I ended up using 10m-40 in mine also...I really like my X530, but I'll have to say it is not the tractor my old 316 is.......
THANK YOU!!!!! For the coupons....
1262 (A50490)
1262 (A50490)
Toro Workman Utility Cart (A51694)
Toro Workman...
2024 Bobcat E35 Midi Excavator (RIDE AND DRIVE) (LIKE NEW) (A50774)
2024 Bobcat E35...
2015 Kubota L2501D (A50120)
2015 Kubota L2501D...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
