What Was John Deere Thinking?
   / What Was John Deere Thinking? #1
Missouri Lad
Bronze Member
Missouri
8N Ford, JD345, JD710A, JD2320
Last summer I notice some play in my front axle pivot pin and bushings on my 1999 JD 345. I wanted to believe this was normal play/movement for 785 hours on the tractor. However, after replacing the three (3) idler pulleys on the drive belt assembly yesterday, I decided to tackle trying to get the front axle assembly off the tractor frame. The "Big" nut that holds the #AM135163 pivot pin is easy to remove, but, there's where it become a PITA trying to get the pivot pin out. You guess it, I have to remove the PTO from the crank shaft first. John Deere engineers could have made the frame 2" inches longer here is this area and save some few words you don't use in church. I had to replace my PTO two years ago, and that was a real wakeup call on getting the PTO off the shaft. When I installed the new PTO I did grease the shaft good. Lucky that I did, as the PTO came off with some help with a wheel puller. Now, I waiting to get my order in from the dealer on the pivot pint and two (2) #M124644 axle bushings. Hopeful I will have it all back in running shape come weekend.
   / What Was John Deere Thinking? #2
Knowing how pto clutches come off I might have thought to loosen the engine's bolts to raise it enough for the pin to have cleared.
art, that thought occurred, but after examining the situation the engine would have to raise some three inches, and from that the PTO may only raise about one inch until it hits the tractor frame. So, that thought went out the window.
2019 FREIGHTLINER CASCADIA TANDEM SLEEPER TRUCK (A54607)
2019 FREIGHTLINER...
2022 JOHN DEERE 6120M LOT NUMBER 191 (A53084)
2022 JOHN DEERE...
UNUSED LANDHONOR TP2-13-08D HYD TREE PULLER (A54757)
UNUSED LANDHONOR...
UNUSED LANDHONOR LHR-RF24 RATCHETS & TOOLBOX (A54757)
UNUSED LANDHONOR...
2019 Isuzu NPR-HD 24ft. Box Truck (A55788)
2019 Isuzu NPR-HD...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
