What was I thinking
/ What was I thinking #1
Hooked_on_HP
Veteran Member
Coal City IL
Ford 1900 FWD Kubota F2100E
A couple of months ago I got a new KK box blade. This weekend I final got arround to making the guage wheels for it. After all the grinding and welding was done it was time to paint it. I was at Big R(farm store) and they had rustolium tractor paint on sale. I picked Old Catipilar yellow. It looked close to the KK color. After I got home and opened it it was quite a bit brighter. Oh well, it's just a box blade.The color is more like the yellow JD uses on their const. equiptment. After I got done (took forever to dry) I took it out and put it with the rest of the atachments. I stood back and looked at everything. The box blade looked great, every thing else looked like crap. So now I have a RFM,Tiller,brush hog and landscape rake to paint.I should have gotten the right color for the BB and saved a lot of work. Does anyone know how to make Rustolium dry faster.
/ What was I thinking #2
After applying the paint. The only thing that will help is temperatures above 50 degrees and humidity lower than 85%. If your weather is similar to our here in southern MI the last week or so. It will be hard to achieve the temperature and humidity. Even in a heated shop.
/ What was I thinking #3
I use a movie light. If it is spray paint from a can I put it in a water bath that is around 100 degrees and let it stay in the hot water for several minutes. I use a 1000 watt movie light and pre heat the metal as much as I can. As I spray the paint I follow the spray with the hot lamp as I am spraying. The paint is almost dry by the time the light leaves the sprayed area. I have not done this while it is real humid but it may work. I usually do this almost every time I use spray can paint and have never had any problems with the painted surface, where I have had problems when I did not follow the above procedure. I just remodeled a kitchen and now have an electric stove with oven to pre heat my smaller metal parts prior to painting and do a little paint baking afterwords. Do not try this in your kitchen your significant other may object and it may taint the taste of any baking she does.
David B
/ What was I thinking #4
HP,
It sure is nice to repaint those attachments, makes them look brand new. But after a couple uses I found mine start to all look the same used again.:) I wouldn't worry too much about one implement sticking out from the others. You can only use one a t a time anyway, right? No one but you will know.
All the rest are regular KK color. I never did like the color,just the price. Nice bright yellow looks a hole lot better than faded dull yellow. I brought the RFM in tonight to start cleaning it up for paint. KK paint jobs are bad to begin with. A good coat of paint will help.
Ford Golden Jubilee Tractor (A66285)
Ford Golden...
Brent 320 Grain Cart (A65640)
Brent 320 Grain...
2000 CATERPILLAR 988F SERIES II WHEEL LOADER (A62129)
2000 CATERPILLAR...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
8" Mini Excavator Bucket (A66285)
8" Mini Excavator...
John Deere 7230 (A62180)
John Deere 7230...
