What usually goes bad with multipower
   / What usually goes bad with multipower #1
tucker2
Hickory,NC
Kubota L1500, Iseki TS1910,Trak King dozer
I looked at a MF35 today, everything looked good but the multipower lever was stuck in down position, tractor ran good but no engine braking going down hill. The guy said it would work but took alot of effort to pull the lever up into high. Is this a indication the multipower is going bad? What usually happens when multipower goes out, is it the Hi or the Lo not working or hard to shift?
   / What usually goes bad with multipower #2
My 1964 MF135 diesel had MultiPower that was stuck in Low range. MP is a hydraulic system and leaks and a clogged filter can prevent shifting from Low to High and back. You loose half of your tranny gears when MP is stuck in Low, but the tractor is useable in Low. You have to remove the heavy top cover on the transmission case to fix that problem.
Good luck.
   / What usually goes bad with multipower #3
Usually too expensive for most folks to consider repairing, unless, you can do it yourself. Ken Sweet
   / What usually goes bad with multipower #4
most of the time the clutches in the multipower start slipping in the high side can get bad enough tractor will downshift to low on its own we overhauled multi power on an 1105 massey we had some years back it was not too bad a job. the multipower lever was never hard to move or got stuck on that tractor could be that something is binding in the linkage of froze up from rust or something.
   / What usually goes bad with multipower #5
G'day sound to me like something is binding in the linkage take it for another drive and see if you can get it into high if you can and it doesn't want to slip then it is just a linkage prob
Jon
Befco Rotary Tiller (A42021)
Befco Rotary...
2017 Bobcat A770 High Flow Compact Wheel Loader Skid Steer (A42742)
2017 Bobcat A770...
2014 FREIGHTLINER CASCADIA 125 SLEEPER (A37757)
2014 FREIGHTLINER...
2016 Ram 1500 Pickup Truck, VIN # 1C6RR7XTXGS346729 (A44391)
2016 Ram 1500...
PALLET OF SAFETY FENCE (A45333)
PALLET OF SAFETY...
New/Unused Self Dumping Hopper (A44391)
New/Unused Self...
