What type tire Ford 3910?
   / What type tire Ford 3910? #1
sawtooth
Veteran Member
Eden NC
Ford NAA, Ford 2810, Ford 3910-1, Ford 3910-2, Ford 4600SU, Massey 2660 HD, Massey 461, Grasshopper 725D, Grasshopper 900D
I need 4 tires for my 3910. What type 14.9x28 do you guys recommend. I will use it for disk harrow and bush hog. Bias tires only please. Thanks
   / What type tire Ford 3910? #2
R-1 Ag tires on the rear. A ribbed ag tire on the front
Ok thanks. I'm looking a firestone super traction 2 tires. These will be 14.9x28 rear. My question is what size front tire to use. Now I have 6.50x16 fronts but wondering if your suppose to go bigger on front when you go bigger on rear tires.
   / What type tire Ford 3910? #4
If you are going bigger on the front (will make it a little harder to get on in some cases) you may need to get a bigger/wider rim. We stepped up a size planning to get a FEL. After finding a backhoe for about the same money as a new FEL I wish I had the stock size steer tires now.
   / What type tire Ford 3910? #5
Do you have an owners manual? The recommended tire sizes are usually found there.
   / What type tire Ford 3910? #6
I like the Gensco airplane takeoffs.
You can get em in tri rib flat proof.
I got some for about 160 w new rims mounted delivered total
   / What type tire Ford 3910? #7
Ours has 7.50x16 tri ribs on front, 14.9x28 rears with a loader.
   / What type tire Ford 3910? #8
Yeah mate, i do think it's the best option to choose from.
Do let me know if it's creation any problem, i will give you the alternative.
___________________
Log Splitters Ireland
Does anyone know if leaving the 6.5x16's up front will be an issue going to 14.9x28 in rear? Not sure if it will look like a dragsters or not. By looking through my manual it looks like somer were shipped from the factory that way but not sure. The 7.5 front tire is about 1.5" taller I believe. But I have no plans for a FEL and like the tighter turning smaller tire.
Second question is now I'm really thinking of keeping the factory style tire (Goodyear long bar short bar). But if this tire offers alot less traction and performance I may just switch to Firestone super all traction tires. Longevity is not an issue for me as I only run it about 20 hours a year max. I do pull a 7 ft disk though so looking for decent traction. So do I loose alot by staying with original style tires?
vergenes (A50657)
vergenes (A50657)
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
2007 MACK VISION (A50854)
2007 MACK VISION...
2000 Ford F-650 TMA Attenuator Truck (A49461)
2000 Ford F-650...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
UNUSED RAYTREE EXCAVATOR MULCHER (A50460)
UNUSED RAYTREE...
