Oil & Fuel What type of oil should be used in a 3020
   / What type of oil should be used in a 3020 #1
rusty022
Michigan
John Deere 3020 New holland TC25D
I have been using Rotella 15w-40. Is that okay or is it more for just diesels? 95% of the tractors run time is for doing hay.
   / What type of oil should be used in a 3020 #2
Awfully good oil that.
No matter if your 3020 is gas. Although, for winter, the synthetic 5w-40 Rotella would flow a lot faster for cold startups. That 15w-40 will be mighty thick at -10. I see you're in Michigan.
It is a 3020 gas. It only gets run a cpl of times in the winter, to move it and get something out from behind it.
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
2013 Lexus ES Sedan (A50324)
2013 Lexus ES...
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
KUBOTA BX2350D TRACTOR (A51247)
KUBOTA BX2350D...
2019 Ford Fusion Sedan (A50324)
2019 Ford Fusion...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52748)
2014 Doyle Dry...
