What type if connections are the rear remotes? Branson 2515h
   / What type if connections are the rear remotes? Branson 2515h #1
nosaj2
none yet
My tractor has not got here yet. I'm ordering a top link so I can put it on as soon as it arrives. Can anyone tell me what type of hydraulic connectors fit the rear remotes? "valve type" or "ball type" or is there a difference or is it something else. First time tractor owner.
   / What type if connections are the rear remotes? Branson 2515h #2
Congratulations! They should be the Standard female 1/2" pioneer Ag style on the tractor.
   / What type if connections are the rear remotes? Branson 2515h #3
I use Pioneer Universal Agricultural Male Tip (1/2”), ISO 5675, Connect Under Pressure - 8010 Series Nipples | #8010-4P-DC.
This is the male tip to go to the tractor with a 1/2" npt thread for the hose.
thanks guys!
   / What type if connections are the rear remotes? Branson 2515h #5
You can use 1/4" hose for a top link. It does not need much flow.
The ball type and poppet type ISO 5675 are supposedly interchangeable.
The connect under pressure feature is in the female side. I have a set and find them to have stiffer springs both internally and in the release sleeve, making them hard to connect when not mounted to a bulkhead.
1264 (A50490)
1264 (A50490)
2006 Ford Fusion SE Sedan (A51694)
2006 Ford Fusion...
JOHN DEERE Q820M LOT NUMBER 244 (A53084)
JOHN DEERE Q820M...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2008 Volkswagen Passat Sedan (A51694)
2008 Volkswagen...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
