What tranny is in the GT 2500 series
   / What tranny is in the GT 2500 series #1
jcomp
Upstate, NY
2009 Cub Cadet GT 2550
Hello-
I am researching a new purchase. What is the specific model of hydrostatic transmission in the CC GT 2544? More specifically the torque rating for the unit? Cub site only shows it as a "cast Iron".
Thanks-John
   / What tranny is in the GT 2500 series #2
The transmission is a Hydrogear BDU-10, but the gearing in the housing is sourced from somewhere else. Don't know what the torque rating is at the rear axle, never seen it listed anywhere.
   / What tranny is in the GT 2500 series #3
Yep, the transaxle assembly is a mixture of parts. The Hydro-Gear hydro drive is coupled directly to the input on the diff housing. The cast iron axle/differential housing is stamped made in China. The powdered metal gearing inside most likely is made in China too. Dunno about the bearings and seals, but you can bet from the lowest cost supplier. IMO, the setup compares to a higher end TuffTorq rear that you'd find in a $6K JD, but is it better?? I dunno. I've only heard of maybe one 2K series failure and a few 3K series.
Joel
   / What tranny is in the GT 2500 series #4
When the 2500 series was introduced in 2003, the Cast Iron tranny was the same as what was used on the 3000 series Cubs. That is what my dealer told me.
Michael
2002 Ford F-350 Crew Cab Flatbed Truck (A51691)
2002 Ford F-350...
Ford Tractor (A50120)
2006 International 9400i (A53473)
2006 International...
SET OF (4) ALCOA 24.5 ALUMINUM RIMS (A53843)
SET OF (4) ALCOA...
1969 Lincoln Continental Mark III Coupe Collectible Car (A51694)
1969 Lincoln...
