What tractor?
   / What tractor? #1
Anonymous Poster
Epic Contributor
I have around 200 acres that I will be eventually farming on. The problem is that most of it is grown up withtrees and brush. I was thinking about the TN75D with the 32LA MSL loader or the TL80 with the 52LA loader. Any suggestions would be helpful.
   / What tractor? #2
First you need to figure out what you will be farming and what implements you are going to want to run. Then you choose the tractor to run the implements you will need.
   / What tractor? #3
Cowboydoc has given the best answer anyone could until we know more about what you intend to do.
Bird
   / What tractor? #4
If you do plan on farming any amout I would get a TL 80, if you only want to farm less than 50 acres a TN 75 will work fine depending on soil. I am in the process of buying a 235 acre farm in which 150 acres are field that I plan to lease out but I will get a TL 80 for running the cutters on the land that is not leased. Old saying is true, you can never have too much HP but you can always have too little HP.
<font color=blue>Robert Turk Jr.</font color=blue>
<font color=blue>Whitetail Splendor Deer Farms</font color=blue>
<font color=blue>Silver Creek, NY</font color=blue>
   / What tractor? #5
I would buy the biggest tractor, with the most Horsepower and features that you can reasonably afford, that will easily do the work. Don't buy less power than you need--- you can always throttle down but what do you do when you need more HP and torque???? Think seriously about a climate controlled cab. It may be expensive, but it will allow you to work in inclement weather. Have fun and be careful. Read the forum on safety!! Good luck! Sam
"I love the smell of diesel in the morning."
Cummins powered 24V Dodge Rams rule!
   / What tractor?
Buy the nicest tractor your non-farming income can afford.
New/Unused Quick Attach Post Driver (A51573)
New/Unused Quick...
2018 Seal Rite SR 700XP Seal Trailer (A52384)
2018 Seal Rite SR...
2008 New Holland B110 MFWD Loader Backhoe (A53472)
2008 New Holland...
New/Unused 7ft Stainless Steel Work Bench with 10 Drawers (A51573)
New/Unused 7ft...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
Komatsu Midi Excavator (A51691)
Komatsu Midi...
