What tractor should I buy?
   / What tractor should I buy? #1
scrimshaw33
Bronze Member
JD 4520 w/ cab and FEL
I have a 100 acre farm in NC. I'm not set on a JD but have been told by everyone I know to go with JD b/c they have had them for decades and with maintenance have had no problems.
80 acres of my property are wooded which I won't really be doing much work with.
20 acres are tillable which I planted in corn this year. Each and every year I'll probably plant some crop (either corn or soybeans) solely for deer hunting. I will slowly bushog the corn or soybeans during the hunting season.
Other than that, I will be using the tractor to maintain my gravel drive way (about 1/2 mile long), move brush and cut timber (plan on getting a FEL and 4WD by the way).
My question, which I have been debating for some time, is whether I can get by with a JD 4510 (39 engine hp, 35 PTO hp) or do I need to go to a 50 hp+ tractor?
I found a JD 4510 with 1500 hours for around $16,000 locally with a FEL and 4WD. If I go with a 50 hp tractor from what I've seen I'd have to spend more which if I have to I will but would rather not. Will the 39 hp be suitable for what I'm doing or do I need more hp?
   / What tractor should I buy? #2
I think you can easily get by with a 39 hp tractor, and even less.
But can't make that decision for you. :)
   / What tractor should I buy? #3
If I understand correctly.. every year you'll be working the ground on 20 acres of cropland that was planted with corn, soybeans, etc.
After the ground has been plowed, disced and ready to plant your gonna plant the 20 acres with a row-crop planter...
And you'll apply fertilizer and a herbicide treatment?
Instead of harvesting the crop you plan to "mulch it" with a bush hog mower for a hunting area.
And you want to do that with a 4510? Do you have a plow or a disc harrow? A cultivator? Sprayer? Planter? Bush hog mower?
Or you plan to hire out the work I just outlined?
Depending upon the answers you provide... the recommendation of a 4510 vs a 50hp tractor could be yes or it could be no.
AKfish
   / What tractor should I buy? #4
You need to know the size of your implements you'll be using. And the processes you'll be doing. How much mowing will you be doing? It could be you spend most of your seat time doing that. You might want to get into something that will handle a larger bush hog. Also, I wouldn't want to plant 20 ac with anything less than a 4 row planter. Although it can do it, that's a load for that tractor. You should be able to find a better deal than $16000 on a 1500 hr 40hp tractor.
Thanks for the info!
I'll be bushogging the 20 acres but will have those planted by someone else who has a large (30 ft?) planter. It took him like 5 or 6 hours to drill all 20 acres this year in corn. I also will hire out the spraying of herbicide treatments and fertilizer from a local coop like I did this year, each year.
So the only things I'll be doing is bushogging the 20 acres, "mulching it", maintaining the property (moving trees and brush, planting smaller 5 acres worth of food plots).
I am planning on getting a bushog, box blade and was going to get a Woods or Landspride rotary tiller instead of a disk and plow. Any recommendations on the size of implements I should get? I guess I was thinking of 6 foot implements. Thanks for the help.
   / What tractor should I buy? #6
I saw the post regarding the size tractor you want / need over on the QDMA site. Over there.....the folks kept telling you to go bigger and bigger. Of course they aint payiing the tractor bill either. :laughing: Also, those bigger implements are going to cost more too.
As said above......the first thing to consider is how big of implements do you need to operate?? If you can be happy with a five foot tiller and a five foot rotary cutter then a 25+ pto hp tractor is likely adequate to power em. Six foot stuff is going to take a heavier tractor and 30+ pto hp.
For me and my heavily wooded property I find a small tractor and five foot implements fills my bill and is more maneuverable in the trees....but I only till a few acres and do mostly trail maintenance.
   / What tractor should I buy? #7
Yep, some folks sure like to spend other people's money!
As an addendum to Foggy's question about the size of the implement, how quickly do you need to do the work? If a "gentleman" farmer, I doubt you're in any rush. Your tasks sounds like you're setting up a hunting camp (mulching the crop, rather then harvesting).
Also, since you're hiring out the planting and spraying, you may want to consider hiring out the hogging too (since you're not going to harvest). The farmers doing the other work probably have a cutter that's big enough to knock out the hogging in a day or so (or less).
That would put you on a larger CUT rather then a full sized utility or farm tractor.
   / What tractor should I buy? #8
Rent a 45-55 hp machine for a weekend. Guaranteed it will make up your mind. I wouldn't be without mine. There is no substitute for HP when you need it. They sip fuel and work in tight spots with ease. For me NH worked out the best with your similar circumstances.
   / What tractor should I buy? #9
If you don't mind taking extra pass or two..mowing,fel work etc. 39hp,maybe in future extra wooded land might have plans 50hp,and of coarse funds at hand..go w/gut feeling.
Thanks for all the help, hard to know what to get without having used one. Great idea in renting one. Wallet likes the idea of a 35-39 engine hp (35 pto), but if money weren't an issue I'd probably go with a 50+ hp compact.
2012 Chevrolet Silverado 2500 HD Enclosed Service Truck (A52377)
2012 Chevrolet...
72In FEL HD Round Back Bucket (A53472)
72In FEL HD Round...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
2017 Big Tex 10ET T/A Flatbed Equipment Trailer (A50322)
2017 Big Tex 10ET...
49" X 79" EXPANDED METAL RAMP GATE (A51247)
49" X 79" EXPANDED...
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
