Rear Finish Mower What to look for on used RFM?
   / What to look for on used RFM? #1
charlz
Elite Member
Meridian Idaho
Kubota B7100D
A guy in my area is selling a used 'low hours' Rankin 60" finish mower. What should I look for when looking at it? Where can you get new blades for this brand when the time comes? I looked at the Rankin website but no manual is listed for this mower nor anyway to order parts directly from them.
Thanks,
Charles
   / What to look for on used RFM? #2
With any implement.. look for repairs.. good or bad.. look at wear areas.. if it uses a gear box.. inspect seals and mounting ears.. check all pullies for bearing play and smoothness... even a big finish mower should turn over by hand...
Soundguy
   / What to look for on used RFM? #3
One of the very first things I look at with any piece of used equipment is the grease fittings and/or greased areas. Do they look like they've never been touched? If so, good chance the previous owner wasn't real big on maintenence. Bad sign. Also, look at the condition of the blades. Are they beat up with curled edges? If so, the mower might have been seing double duty as a bush hog. Not the best thing for some finish mowers. Paint can be a give-away. Cracked paint might indicate bending or flexing in places that aren't supposed to bend or flex. Look for bolts and nuts that appear to have been removed and re-installed. Has there been major repairs done lately?
If possible, have the mower put on a tractor and run it up to speed. Any odd noises? Bad vibrations? Belts slapping?
With some luck, you can even see it in action. How does it cut? If you're buying from an individual, why is it for sale?
2018 John Deere 652R 52in Stand-On Mower (A42744)
2018 John Deere...
2013 Hyundai Sonata Limited Hybrid Sedan (A42744)
2013 Hyundai...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A42744)
2017 Ford F-150...
Ryobi Sliding Compound Miter Saw (A44391)
Ryobi Sliding...
CHECO HYDRAULIC GREASE INJECTION UNIT (A45333)
CHECO HYDRAULIC...
2012 Jaguar XJ Sedan (A42744)
2012 Jaguar XJ...
