Sprayer What to look for in used sprayer
   / What to look for in used sprayer #1
Jerome
Elmvale Ontario Canada
Kubota L245dt
I have a chance to purchase a used 3pt sprayer I know it need some new hoses and at least 1 t what else should I look at????
   / What to look for in used sprayer #2
The basics would be that the tank holds water, the pump works and the sprayers do their thing.
I've been looking for a decent priced used sprayer, and have had no luck at all. I'm debating between buying new and building my own, but sure wish a used one will turn up that doesn't cost as much as the new ones.
How many gallons, what type of pump and what is the price?
Eddie
I took a better look at it yesterday. I could not bring it home from the neighbors as there is a sleeve over the lift pins making it to large for my lift arms the tank looks solid though and the pump turns. I hope to get it here for do a better test over the week end. He wants $200 for it and it looks like another $100 to get it running.
   / What to look for in used sprayer #5
I have a couple of used 100 gallon sprayers. One I have had for more than thirty years. The other, somebody else had for 25 or so, and I have had for ten. When I was using them regularly, I sort of did "progressive" maintanance on them, and didn't have to fix too much stuff at once. They both sat out unused for a few years, and when I needed one last year, there was so much to be done that I said to heck with it and just bought a new 50 gallon sprayer from TS. I really didn't need 100 gallons, and I have so much trouble working on stuff now with carpal tunnel in both hands, and I needed to use the sprayer "right now", so I sprung for the new one. Usually, trouble with the old booms being bent or rusted through is the biggest problem I run into on a used one.
This is the one I was going to try to resurrect. The booms were just gone when my brother bought it at a sale for me to repair. I had it rigged with a piece of pipe a few years back, but that never worked very well.
My advice----get a new one.
I got the Sprayer home and did some testing. The pump works great after I put the inlet hose on the inlet side and the outlet on the outlet side.
I have to replace some hoses which seemed to have disintegrated in the sun, is there a better UV stable hose?
I also have to replace one valve which also disintergrated in the sun. I use a product called 303 on my plastic canoe to protect it would this work on thes parts?
   / What to look for in used sprayer #7
If you're fussy and have lots of money order some hose from a sprayer manufacturer. If not, go to a commercial hose supply place and buy some major brand name stuff rated to 150-200 psi. I've asked for uv-rated sprayer hose before and my local farm supply place sent me cheaper no-name hose than I bought from the local industrial place. Even the big-name hose makers don't seem to like to promote their stuff as uv-rated though.
303 canoe stuff? Haven't a clue, but maybe I need some for my canoe and kayak... :) Might not hurt on my plastic spray tanks, too.
   / What to look for in used sprayer #9
Thx, will have to see if I can find some locally.
2003 Mercedes-Benz SLK Coupe (A50324)
2003 Mercedes-Benz...
2014 MAGNUM PRODUCTS LIGHT TOWER (A52472)
2014 MAGNUM...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2018 Bobcat T595 (A47384)
2018 Bobcat T595...
Welder (A50121)
Welder (A50121)
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
