Tires What to fill tires with
   / What to fill tires with #1
PLUMBER
Bronze Member
Fairfield county , CT.
JD 2520
I want to load the tires of my 2520 but would rather not use calsium i heard about beet juice (i think) were can i find it and whats it cost . Thanks for the help
   / What to fill tires with #2
PM JDFANATIC and ask about the beet juice, because he uses it.
   / What to fill tires with #3
The beet juice is in fact called Rim Guard. Do a search here on TBN for Rim Guard and you will get plenty of hits. It has been discussed thoroughly many, many times. In my opinion it is the best stuff to load your tires with.
   / What to fill tires with #4
Plumber,
I did fill my tires with RimGuard and am happy with the results; if it leaks out it won't kill the grass or our animals, it has more density than water/anti-freeze/washer-fluid (though less than calcium chloride), it won't corrode my rims, and it won't freeze. /forums/images/graemlins/tongue.gif
   / What to fill tires with #5
Call around to your local tire dealers. They should be able to direct you to someone in the area that does ag and industrial tire work. They will be the ones that will be able to fill your tires. They will come to where your tractor is and do it on site. Unless you have tubes in your tires, I would go with Rim Guard. That is what I have in mine. I used to work in a tire shop and did many ag tires with Calcium Chloride. If handled properly it is not a problem. It is cheap and effective and has been around for years and years. Nowadays, with the enviromental concerns of Calcium Chloride spills, I believe that Rim Guard makes more sense and it won't rust out your rims, either.
   / What to fill tires with #7
I got the beet juice in the tires. helped a lot, nice and stable . tires will be dangerously heavy, so carefull if you remove them later.
   / What to fill tires with #8
RimGuard sounds like the best stuff. It's got great specs. Does anyone know how much it costs?
BTW: I could find no indication that it is in any way related to "beet juice."
   / What to fill tires with #10
I know for a fact that Chappell in Milford and Brentwood and at least one place over in Keene that uses Rim Guard to fill tires. I am sure there are others.
2019 Doosan DX225LC-5 Excavator (RIDE AND DRIVE) (VERY NICE) (A50774)
2019 Doosan...
2023 Bobcat T66 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T66...
20' Sea Container Mobile Hospital (A50774)
20' Sea Container...
International 56 2-Row Pull Cornplanter (A50774)
International 56...
2019 Bobcat E32i Mini Excavator (A50322)
2019 Bobcat E32i...
