What to do with bad gasoline?
   / What to do with bad gasoline? #1
srjones
Platinum Member
Columbia County, Oregon, USA
Mahindra 2015HST & Mitsubish R1500
I've got about 10-15 gallons of bad gasoline in various small cans that I've collected over the years and now I'd like to get rid of it.
However, it's not a good time burn, and when I've tried to burn it in past, it ended up smelling like gas for months.
I thought about adding it to woodchips and sawdust in a standard 32 gallon garbage can to let it absorb and then burn it in 3 or 4 months.
Or is there a certain type of business that will take it? (like they do motor oil recycling?)
Or is there something or some process that will break it down into it its basic atomic building blocks?
Thanks in advance for the suggestions.
-Steve
Thanks Paul,
I should have first gone looking at recyclers. As I started following the links and doing more searches, I found that gasoline disposal is categoried as hazardous waste. Fortunatly, another place has a list of where to get rid of it.
Metro: Guide to hazardous waste
However, I'm still open to ideas on taking care of it at home.
-Steve
   / What to do with bad gasoline? #4
How bad is bad? You could mix some with fresh gas and use it. Years ago when I worked at a International truck dealer I got gas and diesel fuel that had been mixed together all the time. They didn't want it since they had to pay to dispose of it as mixed hazardous waste and I was more than happy to take it for free. I would fill up my old rust bucket 1977 Ford P/U and add 2 or 3 gallons of the "dieselene" to it. Over the years I must have run 500+ gallons through the truck with no ill effects.
Here's another thought. Ask your local fire department if they want it. They might use it for firefighter training. Never hurts to ask.
I have this link on my website homepage. It's a great resource for finding recyclers in your area for almost everything. Earth 911 » Making Every Day Earth Day, Reduce, Reuse & Recycle, Green Lifestyle
   / What to do with bad gasoline? #5
Does your county collect gas, paint and other materials?
My county takes these kinds of materials once a month, no charge. You should have seen their faces when I showed up with half a pickup full of old oil, gas, paint, pesicides, anti freeze, and plant killer. :D
They also take batteries and I think old tires. This is one of those things are county does right. Otherwise people would just dump this stuff along the roads.
Later,
Dan
   / What to do with bad gasoline? #6
Makes a good short term grass killer around fences...
OK SUE ME!! :D
   / What to do with bad gasoline? #7
-Steve
Theres energy there that you could have, but if you just burn it as waste you lose it. Mix it with some good gas and use it in your lawnmower and other gasoline engines. Just dont store the diluted mix in the fuel system. - Run it out on the task then put a little fresh gas in behind it.
larry
   / What to do with bad gasoline? #8
-Steve
NO!! Unless you are interested in creating a potentially lethal bomb with enough energy to send your house to a recycler.
   / What to do with bad gasoline? #9
-Steve
Hi Steve
Had a DEP man tell me it was illegal to bury paint cans with paint in them. It couldn't even be dumped into the trash for garbage truck. However, take the top off the paint can and let it evaporate, then toss it or bury it. It's OK.
You could put it in an open container ( in a safe spot) and let it evaporate. If it were me, I really like the suggestion posted here of mixing with fresh gas. Only if the gas wasn't dirty or rusty; just not fresh gas. That's probably what I would do.
Cheers....Coffeeman
   / What to do with bad gasoline? #10
I use my old gas to clean up oily and greasy parts.
1993 Ford F-150 Pickup Truck (A52377)
1993 Ford F-150...
2007 FORD F650 XL SUPER DUTY FUEL & LUBE TRUCK (A51406)
2007 FORD F650 XL...
2005 Freightliner M2 106 Box Truck (A52377)
2005 Freightliner...
2015 INTERNATIONAL LONESTAR SFA 6X4 ROAD TRACTOR (A52706)
2015 INTERNATIONAL...
2016 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2016 FREIGHTLINER...
