What to do, Frozen E-brake?
   / What to do, Frozen E-brake? #1
jmusser15
Fulton County, PA
Kioti RX6010
Well I am going to chalk it up to my first winter owning a tractor. I usually keep it in the garage but went out yesterday to plow the first snow, parked the tractor outside and set the emergency brake (this is a habit, I don't even think about it when I do it). Last night when I went to move it into the garage, the emergency brake froze and the brakes will not release. It is not supposed to get above freezing today and I need to get it moved back into the garage. What can I do to get the brakes to release? I already tried moving slightly forward and backward to get them to release but no luck.
   / What to do, Frozen E-brake? #2
Bucket of warm water? Not sure I understand exactly what's frozen, but 5 gallons of hot water will thaw most things out.
   / What to do, Frozen E-brake? #3
Is the cable coated in grease or something else that froze? Generally linkages don't freeze no matter how cold it is.
   / What to do, Frozen E-brake? #4
Throw a tarp over it and put a heater under the tarp.:thumbsup:
When I set the emergency brake, the brake pedals are depressed. The emergency brake holds the brake pedals in the depressed position. I have released the emergency brake handle and the brake pedals still stay depressed so I think the brakes themselves have some moisture in them and they froze. I guess I need to know how to get the brakes to release. It isn't a frozen cable issue with the emergency brake handle.
   / What to do, Frozen E-brake? #6
:thumbsup: I agree with Egon. I have had frozen linkages which thawed just from the heat of the engine running at idle. Be careful of exhaust fumes, but maybe try a tarp and let the tractor idle.
   / What to do, Frozen E-brake? #7
The pivot shaft for the brake pedals probably has a grease fitting. You may be able to give it a few shots of grease and displace the little bit of ice.
Also, have you tried pulling the pedals back up by hand? Maybe even giving them a good jab with your foot would free them. The brake system is pretty beefy, unless you go crazy, you shouldn't be able to bend or break anything.
   / What to do, Frozen E-brake? #8
Do you normally use the brakes or is the first time that you have used them for some time? In the winter I usually use the other brake I drop the implement because I would never plan to stop on a hill.
Craig Clayton
   / What to do, Frozen E-brake? #9
Looks like I have the same tractor as you have and I have the same problem. I do not set the brakes for any length of time now,and block if needed.I have a small torpedo heater that runs on kerosene.I place it at a safe distance from the underside of the brake linkage and run it for a few minutes.Usually 5 to 10 minutes frees it up.
I just took it in for service and told him that was one of the few problems I have with it,and stated that I doubt anything could be done,because I believe it to be a design flaw.He said he might be able to solve it,we will see when I get her back. If he solves it I will try to find out what he did and relay the answer to you.
   / What to do, Frozen E-brake? #10
I agree with previous posters. After you free it, I would be sure its lubed and I would never use it in the winter. I always find a flat place to stop and drop my implement / fel.
2006 Toyota Tundra 4X4 Pickup Truck (A53422)
2006 Toyota Tundra...
2017 KENWORTH T880 (A53843)
2017 KENWORTH T880...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
2008 Caterpillar 303.5C Mini Excavator (A52377)
2008 Caterpillar...
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
