What tires for JD 8200 Grain Drill?
   / What tires for JD 8200 Grain Drill? #1
Pecosbill7
Fredericksburg, Tx
John Deere (2)
I have a John Deere 8200 grain drill in need of new tires. Original Tires say Dayton Grain Drill 7.60-15SL on the side. The only tire I have seen that looks to be similar to the original is the Firestone Duo-rib. I am concerned that I need to keep the drill at its exact original height in order to make it plant at the correct depth. Am I justified in having this concern? Has anyone found any other tires that work as well or better? Has anyone used these duo-ribs and have an opinion on them? Thanks. Bill
   / What tires for JD 8200 Grain Drill? #2
Duo-Ribs came standard on a lot of grain drills. Supposedly it keeps the drill straight when planting across slopes. A lot of guys just put whatever size tire they had on them. I don't know if it affects the planting depth, but their oats, wheat, or barley always came up.
Thanks!
   / What tires for JD 8200 Grain Drill? #4
I still have a set of P235 R15 I took off my 1988 Ford P/U on mine. Work great over many years, trouble free.
   / What tires for JD 8200 Grain Drill? #5
7.60-15 should also be available in a rib implement tire. Any tire that size will be close enough to deliver a reasonable amount of seed. Use tire manufacturer dimensional data to compare any other size you consider.
2021 Chevrolet Tahoe 4x4 SUV (A42744)
2021 Chevrolet...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A43003)
2018 KENWORTH T680...
2018 KENWORTH T680 TANDEM AXLE SLEEPER TRUCK (A43003)
2022 John Deere 1025R Tractor (A44391)
2022 John Deere...
Ryobi Compound Miter Saw (A44391)
Ryobi Compound...
2018 PETERBILT 389 (A45046)
2018 PETERBILT 389...
