What thickness flooring for shop loft
   / What thickness flooring for shop loft #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
We are talking about adding a shop loft in one of the bays of the shop. this would be to create a second story... Right now it is a 24X45 dimension, with abit taken up by a stairwell. Looking at the math, we are looking at 14" I Beams (wood) 16 OC. I am thinking 3/4 would be enough but a friend said 1 1/8. Halfwould be office space and half would be storage. Nothing grossly heavy but not 16 rolls of toilet paper either.
   / What thickness flooring for shop loft #2
1 1/8” is a very high quality subfloor. With 16” OC joists, 3/4” t&g glued and fastened plywood or OSB would be just fine. Their is nothing wrong with 1 1/8” though.....but every house I’ve built for myself has 3/4”
   / What thickness flooring for shop loft #3
I don’t see anything wrong with 3/4. Without piecing together layers I don’t even know where to get 1-1/8.
   / What thickness flooring for shop loft #4
Like what has been stated above, 3/4" is what is code in most places. If you knew in advance that it would be supporting very heavy weight, then 1 1/8" might be called for.
   / What thickness flooring for shop loft #5
I have two mezzanines in my shop,,
one floor is 3/4" hardwood boards, the other is 3/4 inch poplar boards, topped with 3/4" T&G oak flooring.
the single board floor is strong, but, it is like walking on a "sponge", it is on 24" OC steel beams.
the double floor is like walking on concrete.
The double floor is setting on 8X12 beams 4 feet on center,,
Even with the 4 foot center spacing, the floor is solid.
   / What thickness flooring for shop loft #6
3/4 advantec is pretty solid on 16” centers. Another 3/4 layer does firm it up though. It would be about $1000 to cover that in 3/4 plywood at local pricing so I personally wouldn’t double it.
   / What thickness flooring for shop loft #7
Whatever you decide, use two layers and split the seams to get the thickness you want.
   / What thickness flooring for shop loft #8
if you can source ungraded lumber, putting down 1.5" rough sawn planks might be a decent option.
   / What thickness flooring for shop loft #9
On mine I have 16” centers and 3/4 osb t&g, it’s plenty sturdy for my uses, but I don’t use it daily, just for storage. If I was using it as a office and such, I’d cover the osb subfloor with a laminate or something to take wear and tear and to be able to keep clean.
   / What thickness flooring for shop loft #10
What type of flooring are you going to put over the sub floor? If it's anything besides tile, you will be fine with 3/4 T&G
Assuming that your joists are sized correctly for the span, then 3/4 is overkill for 16 inches. Most houses have 3/4 T&G plywood on 24 inches. The 1 1/8's is crazy heavy to handle and install. It's really nice once installed, but I rarely use it because of it's weight, price and lack of need for that much additional stiffness. More importantly, don't forget the glue!!!! Nothing worse then a squeaky sub floor after it's all said and done.
CAT D5K2 LGP Dozer (A42203)
CAT D5K2 LGP Dozer...
2003 John Deere 655C Loader (A42203)
2003 John Deere...
2018 FORD F-550 SERVICE TRUCK (A45046)
2018 FORD F-550...
KOMATSU D51PX-22 (A45046)
KOMATSU D51PX-22...
2017 Ford Explorer AWD SUV (A44572)
2017 Ford Explorer...
2010 GMC Terrain SUV (A42744)
2010 GMC Terrain...
