Hello,
As many of may already know, I just can't shut up about my new JD2038r. At the moment, the only attachments are the loader and a 6' rotary cutter. However, one of the jobs of the tractor (and the 2305 that preceded it) is some driveway maintenance and especially clearing snow. Our driveway is almost 500' long and is gravel for all but 30'. Given that I have used a grader blade for both light gravel maintenance and as my main snow clearing tool, I am wondering what size blade I need for my new tractor. My old 2305 pulled a 5' cheapo blade with no problems and despite being rusty & ugly, it did do a good job at angling and rolling the snow off the the side. I have my eyes set on an everything attachments grader blade for my new 2038r. I intend for this to be the last grader blade I ever buy so I am deliberately getting one that has tilt and offset options as well as being sturdy built. What I don't know is what size I should get. While a 5' option is available I am ruling this out as being too small--once angled it won't even clear the tires of my new tractor (about 5' themselves measured outside to outside). I think the six footer would work, but again, once angled I am afraid that I will just cut out my own tires and no more. EA does have a 7' available and that is attractive as I should be able to angle and still clear a little further beyond my tires. Also, the offset is attractive as I can clear some patches of snow without actually having to drive over it. As for gravel maintenance, I mostly used my old blade turned around backwards to help collect gravel that worked its way to the edge and nudge/smooth it back into the center of the driveway and leave it looking attractive. I am NOT planning on using this blade as a way of cutting new, broad paths in the driveway or really digging much at all into either gravel or the clay soil beneath it. This is NOT a box blade replacement. The only thing I intend to both dig and move is snow, up to about 1' thick. That being said, I would not completely rule out angling the blade severely (maybe offsetting as well), using it nearly edge on as a way of adding just a bit more of a ditch to the driveway (by ditch, think a couple of inches deep & wide, not feet deep and wide).
So, given my needs, is it generally safe to assume that a jd2038r (37hp) would be enough tractor to operate a 7' blade in the snow? I am pretty sure my old 2305 could have handled a 6' blade, but I never actually tried that.
Thanks so much in advance for those who know more about rear blades than me.
SI2305 (Old handle, new tractor)
2018 jd2038r, loader, 6' rotary cutter and hopefully soon to be new EA rear grader blade
