what size trailer?
   / what size trailer? #1
BoFuller
Veteran Member
Arizona
2008 Kubota L3400
I have a tele handler that weighs about 26,000 lbs. If I was wanting to tow it places, what size trailer would be required? And what size truck to pull it? Anything short of a big rig?
   / what size trailer? #2
I'd say at least an F-550 - F-750 size truck and a 30k or so trailer would be a good low end, and a single axle semi with a 40k trailer would be good. One could even get by with a dump truck and longer tag trailer, or a big, tandem rollback. You will get many mixed views on this. Good luck.
Kyle
I do have a dumptruck - a 1980 F8000
   / what size trailer? #4
They do make some pretty long tag trailers, check the ratings on your truck and see what's doable. Finding a decent 30-45k tag trailer is easy, finding one long enough may be a bit tricky.
Kyle
   / what size trailer? #5
A good air tag trailer 15-25 ton trailer and a f650 or 4400 international fl70 or bigger. I have seen a triple axle gooseneck behind a small international haul that kind of load. Also depends if your in flat lands like me or mountains.
Thanks for the tips! :thumbsup:
2013 International DuraStar 4400 Altec AM547 50FT Material Handling Insulated Forestry Bucket Truck (A51692)
2013 International...
2025 SDLANCH SDLD25 UNUSED Crawler Dumper (A53117)
2025 SDLANCH...
2015 Ford Taurus Sedan (A51694)
2015 Ford Taurus...
2019 Freightliner M2 106 Truck Recycling Truck (A51692)
2019 Freightliner...
2012 Mack GU713 T/A Gardner Denver Kill Truck (A52377)
2012 Mack GU713...
2019 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2019 John Deere...
