Tractor Sizing What size tractor do I need?
/ What size tractor do I need? #21
You might want to check this place out.
<A target="_blank" HREF=http://www.nges.com/index.html>http://www.nges.com/index.html</A> I think they are about 100 miles from you, over near Summerville, Ga. Looks like they carry Yanmars, plus you can check out the Bransons.
/ What size tractor do I need? #22
I didn't even know that North Georgia Equipment had anything on the web, Norm. I'll give a positive report on them also as I have done business with them on several occasions and they are top notch. They have a lot in Rock Spring, which is on US 27 north of Summerville around the Chickamauga area, and a lot in Armuchee, which is on US 27 south of here and just north of Rome.
Jeff
/ What size tractor do I need? #23
I thought they must be pretty close to your place, Jeff. I'm going to check out the Rock Spring location when I get back to the Trenton farm in the spring. It's only about 20 miles across the mountain and I want to check out the Bransons.
I went to North Georgia Equipment to check out their Yanmars
but they only had 2 small ones on the lot. I ended up buying a Branson 3510. It's supposed to be delivered today. Thanks for the input.
Ken.
/ What size tractor do I need? #25
Good for you, Ken. I'm very impressed with what I read about the Bransons. From what I understand, South Korea is coming on strong in the technology and industrial field. Will probably be the next "Japan".
/ What size tractor do I need? #26
You are going to love the 3510. We sell them and they are rock solid top quality tractors.
2017 INTERNATIONAL LF687 DAYCAB (A60736)
2017 INTERNATIONAL...
SAND BLASTER AND GEAR (A60736)
SAND BLASTER AND...
2017 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A60352)
2017 Peterbilt 567...
2012 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2012 DRAGON 150...
Dodge Charger (A56859)
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
