What size socket
   / What size socket #1
davecharles
Bronze Member
Carbondale IL
Yanmar 2220D Yanmar 240D
I'm getting ready to pull the crankshaft on my 240D and need a socket for the large nut that holds the front pulley. I don't mind buying a new socket but need to know what size. The nut is about 1 7/8". Does anyone know the correct size so I can get the right one on the first try. Is the flywheel nut on the other end of the crank the same size?
Dave
   / What size socket #2
The way to measure your nut size, is to take the reading from flat face, to opposite flat face. If possible, use a vernier caliper. If you don't have one, then a good ruller, or tape. Your reading will tell you the proper socket to buy.
   / What size socket
Thanks Woodchipper,
I can't reach far enough onto the cup with my caliper to get a good measurement. I am hoping someone out there will know what socket they have used for the project. It's 20 miles to town so I need to get it right on the first trip.
Dave
   / What size socket #4
I just measured a nut and they are 46mm across (flat to flat).
   / What size socket
Thanks Aaron, That is what I needed. I am Going to Dallas next weekend, How far is your shop from there.
Dave
   / What size socket
Dave
   / What size socket #7
We are about 2 1/2 hours NW of Dallas.
   / What size socket
I went to my local Rural King and picked up a 1 13/16 12 pt socket (close to 46mm) and it worked perfectly.
Dave
   / What size socket #9
Here's hoping you get it done.
If you're interested in getting a pristine 240D, apparently the people who bought ours back in the fall of 2009 before we bought our Jetta TDI are trying to sell it.
Here's a photo of it from back then.
Ralph
   / What size socket #10
You should visit Harbor Freight while in Dallas and just get yourself a set of the heavy duty sockets (7/8" up to 2" + metric equivalent of same if you want) No tractor owner should be without them. I picked my sets up for $49 each several years ago when they were on sale and they have a lifetime warranty. The ball that holds the sockets to the ratchet fell out and they replaced it with a new ratchet, no questions asked.
2007 Ford Taurus SE Sedan (A51694)
2007 Ford Taurus...
2012 Ford F-250 Pickup Truck (A51692)
2012 Ford F-250...
Ground Works Fertilizer Spreader (A51573)
Ground Works...
2017 Makita HM1307CB 35lb Demolition Hammer (A52377)
2017 Makita...
