What size socket??
   / What size socket?? #1
rosey
Appomattox, Virginia (Central Va.)
Kubota BX2200
I know that there was a post some time ago but I can't find it. What size socket do I need to remove deck blades??....are they reverse threads??..Thanks
   / What size socket?? #2
30 millimeter and no they are not left-hand thread spindles. /forums/images/graemlins/grin.gif
   / What size socket?? #3
If 30mm u can divide by 25.4 (25.4mm=1") and get 1.1811 so a 1 3/16 (1.1875) socket will work too.
   / What size socket?? #4
</font><font color="blue" class="small">( If 30mm u can divide by 25.4 (25.4mm=1") and get 1.1811 so a 1 3/16 (1.1875) socket will work too. )</font>
Or, you can multiply the metric dimension by .03937 and get the English (American) equivalent.
Example: 30 x .03937 = 1.1811.
Better to buy the metric sized socket then use the English (American) equivalent. Using a 1 3/16ths (or 1.1875") socket will be a loose fit which will eventually round off the corners of the attaching bolt. It's also better to use a 6 point socket rather then a 12 point. A 6 point is less likely to slip on the bolt.
   / What size socket?? #5
If you check the owner's manual, it lists the nut as 30.2mm. It seems weird to see this on a Kubota. I have not done the math, but my 1 3/16" socket fits well, and I have not seen any evidence of rounding after having the blades off 30-40 times.
Will
   / What size socket?? #6
"it lists the nut as 30.2mm. It seems weird to see this on a Kubota. I have not done the math, but my 1 3/16" socket fits well "
That is a rather unusual call out, but in this case, 30.2 mm converts to 1.1889 (just over 1 3/16ths). Sounds like Kubota bought or used English sized fittings, at least in this application, then converted the English size to millimeters.
Of couse, the call out may be 30 x 2.0 which is a 30 mm Ø and 2 threads per mm (rather a fine thread for the application, though)...so, the use of an English sized nut seems to be the more sensible answer in this case.
   / What size socket?? #7
I use a 30mm socket which is a six point. Rarely trust those 12 point sockets for that torque.
   / What size socket?? #8
Roy, The threads sure aren't 2 to the mm, as you guessed they weren't. It is strange on a tractor where everything else is metric (I bought a set of 1/2" drive metric sockets just for the tractor.)
Will
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
2011 Toyota Corolla Sedan (A53117)
2011 Toyota...
2003 GMC C7500 16ft Cab and Chassis Truck (A51692)
2003 GMC C7500...
2001 JOHN DEERE 310G BACKHOE (A52705)
2001 JOHN DEERE...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
2015 CHEVROLET SILVERADO 2500HD (A53843)
2015 CHEVROLET...
