Rotary Cutter What size rotary cutter for a TC55DA?
   / What size rotary cutter for a TC55DA? #1
lug nut
Jackson,TN
New Holland TC-55 DA
I will be cutting between 10 and 15 acres of our pasture and have considered doing some bush hogging on the side for other people in our area. I am thinking a 7' medium duty cutter will work well. What are your thoughts?
   / What size rotary cutter for a TC55DA? #3
It would easily pull a 8 footer.
8' screams right along and scalps less than a 7'
however it's a ton more money than a 7 footer too.
a 10 footer might be pushing it.
   / What size rotary cutter for a TC55DA? #4
I've seen plenty of ford/ NH 5610 /II / S mow with 10' mowers.. a double spindle 10' might make it unless he's doing land clearing with it..
Soundguy
   / What size rotary cutter for a TC55DA? #5
Your horsepower will easily handle 7' in all situations.
Are you looking for coverage or utility? A 7' mounted rig is the best for utility work but you could handle up to 15' pull type depending upon the amount of growth and ground speed.
If you don't know, split the difference on an 8' mounted unit and make the most of all situations. Or, buy two different mowers.
I'm looking for coverage and something that I can transport easily on a trailer. I have an 18' dovetail bumper pull trailer now, but I am looking to buy a large gooseneck trailer in the near future.
   / What size rotary cutter for a TC55DA? #7
Sounds like a 7'.. maybee 8' limit.. unless you invested in a v-10' cutter.
Soundguy
   / What size rotary cutter for a TC55DA? #8
i would suggest against a 3pt unless you have weight in the front or something. I have a DX55 and use a 6' Mohawk that is a little over 1000 lbs. Without the loader on it, you can almost get the front wheels off the ground if you arent easy on the clutch in some situations. With the bucket, its obviously no problem.
   / What size rotary cutter for a TC55DA? #9
I guess they aren't putting metal in these new fangled tractors anymore.. on most 'old' tractors.. 6' mower means 30ish hp and you are good.. lift and all... oh well.. times have changed..
soundguy
   / What size rotary cutter for a TC55DA? #10
soundguy
ummmm my 5' MIGHT weigh 400 lbs.... a foot larger for another 100lbs?
but a 1000lb hog 6'.... thats SERIOUS HEAVY DUTY.... NOT what you would find on most 'old' tractors of days past....
My neighbor picked up his round bails... estimated between 800-1000 lb on his hold narrow front end something something.... he had 400lbs of weight chained to the front and you could still see the front end get light when he picked up the bails....
RHINO NITRO FN15 FLEX-WING ROTARY MOWER (A50459)
RHINO NITRO FN15...
1000 GALLON DSL TANK (A50460)
1000 GALLON DSL...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A48081)
2009 Hino 268...
LAYMOR SWEEPMASTER 300 SWEEPER (A50458)
LAYMOR SWEEPMASTER...
New/Unused Quick Attach Pallet Forks (A48837)
New/Unused Quick...
2018 CATERPILLAR TH255C TELESCOPIC FORKLIFT (A50458)
2018 CATERPILLAR...
