What size PTO shaft?
   / What size PTO shaft? #1
35X
Hi,
I have a Massey Ferguson 35X tractor with a 5 foot slasher, the problem is I seemed to have misplaced the PTO shaft from it.
I need to find a replacment, I did a rough measurment and came up with around 1230mm in length.
The thing I am unsure about is what thickness shaft I need to handle the power and is the spline setup pretty much standard or do I need a specific type to suit the tractor?
Hi,
When I last looked at the tractor both ends on the tractor end and slasher end looked the same. Does that sound about right?
Another question.. Is there any issues with using a shaft that has a rating of 100hp behind the MF35? Assuming it is 1/38" 6 spline? Will the bigger shaft cause any issues?
   / What size PTO shaft? #4
Yes, a lot of them are the same on both ends, others have a round bore on the implement with a shear pin. I can't see any problems using a more HD shaft.
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A53472)
GOODYEAR SET OF...
378663 (A51573)
378663 (A51573)
2016 KOMATSU D61PXI-23 CRAWLER DOZER (A51246)
2016 KOMATSU...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
2012 Honda Accord LX Sedan (A51694)
2012 Honda Accord...
