What size plow for my L4630..
   / What size plow for my L4630.. #1
TheDoctor
There is a JD 145F 3-14 for sale in the paper for $250 obo. My soil is essentially all sand. Is this too much plow for the soil with this tractor? Also I assume it has a class 2 hitch setup, does one just change out the attachment on the plow to make it a class 1 or is this a bad idea?
   / What size plow for my L4630.. #2
Doctor:
The general rule of thumb is 15hp / plow share. Your 4630 nets out to about 45hp, so you should be in good shape, especially if your soil is easily tilled.
As far as converting from Cat. I to Cat. II, you may be able to get by with a quick hitch. Some quick hitches are adaptable to either Cat. I or II. Supposedly my SpeeCo quick hitch can do this, although I've never had an opportunity to try it out.
Sounds like a good buy. Good luck!
Rick
   / What size plow for my L4630.. #3
I don't think that plow would has a cat. 2 hitch, it more than likely has a cat. 1. Check it to see.
   / What size plow for my L4630.. #4
The neighbour has a 3 furrow Kverland that is Cat 1.
Ken
   / What size plow for my L4630.. #6
Bushings won't help, his tractor is Cat 1.
   / What size plow for my L4630.. #7
You may find you have more power than you can put to the ground so the plow may still be too large. My L4310 will pull 2 14's pretty well but our ground is tight. CUT's suffer from light weight sometimes. You might be able to pull it if you have 4wd.
GregH
I do have the 4WD but have R4 tires not ag. I called the guy. He doesn't know what size the hook up is, but said he used it on his 3020. It is reportedly in good shape but he doesn't have a hydraulic ram on it . It is about 30 min from here so I will probably go look at it. Anything special I need to watch out for?
   / What size plow for my L4630.. #9
</font><font color="blue" class="small">( Bushings won't help, his tractor is Cat 1. )</font>
Yes, and those bushing aren't going to help with that 6 inch vertical difference, are they? /forums/images/graemlins/blush.gif Maybe I've been working a little too close to the solvent tray. /forums/images/graemlins/tongue.gif
Slim
   / What size plow for my L4630.. #10
6" vertical difference? I guess, but most stuff doesn't rigidly follow the SAE rules. The bushhog and snow blower here have cat 1 / cat 2 hookup, just the pins flopped around on either side and the top link about 3" higher on the cat 2.
1996 Lincoln Town Car Sedan (A50324)
1996 Lincoln Town...
Westendorf Gravity Wagon (A50514)
Westendorf Gravity...
Land Honor Quick Attach Bale Spear (A50515)
Land Honor Quick...
2002 International 4400 SBA 4x2 Flatbed Truck (A49461)
2002 International...
CATERPILLAR D6R XL CRAWLER DOZER (A51406)
CATERPILLAR D6R XL...
2023 CATERPILLAR 279D3 SKID STEER (A51242)
2023 CATERPILLAR...
