what size line for return to sump ??
   / what size line for return to sump ?? #1
kenmac
Super Member
The Heart of Dixie
McCormick CX105 Kubota MX 5100 HST, Kubota ZD1021, Kawsaki Mule 4010 trans 4x4
I added a return line to sump on my yanmar from outlet loader valve. I used 1/2" for the return . Should this line be 3/4'' ??
   / what size line for return to sump ?? #2
if you're not experiencing any undue noise or heat it's probably ok but rule of thumb is always make the return line from your valve larger than the inlet. you may not have enough flow to make a difference but if your not sure of your return line size err on the larger side of choices
don't know about the heat. No noise. Just didn't know if I was returning enough fluid with 1/2. I may try to make it larger ( if I have the room ) this winter.I believe I'm also returning some fluid through the 3 pt in addition to this 1/2' return line I added
2014 International DuraStar 4300 Terex BT2047 47ft Crane Truck (A48081)
2014 International...
2007 Volvo VNL Truck Tractor (A50397)
2007 Volvo VNL...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
2017 Makita HM1307CB 35lb Demolition Hammer (A49461)
2017 Makita...
FRUITLAND VACUUM PUMP (A50854)
FRUITLAND VACUUM...
2012 Ford Fusion SE Sedan (A48082)
2012 Ford Fusion...
