What size is that pin?
   / What size is that pin? #1
Dave from GA & KY
Bronze Member
Live in GA farm is in KY
Kubota M7060 Kioti CK35
Hey all -
I've got a CK-35 and I lost one of the pins that holds my 3 pt. sway bars on the tractor. It's the bottom pin - or the one that attaches it on the tractor end. As I remember it, it's about 3/8" diameter and about 3" long with a washer and clip pin.
The tractor is 200 miles away at the farm and I want to pick up a few of those pins before this weekend. Anybody know what size they are and if they're available at TSC or someplace?
Thanks!
Dave
   / What size is that pin? #2
It's a 12mm pin, with a useable length of 42mm.
You may want to consider using a high strength bolt with a lock nut if you can't get to a dealer. The pin is probaly not available at TSC.
   / What size is that pin? #3
I made two extras out of the rear suspsension U-bolts from a chevy truck after loosing one in the woods. Making an extra, being prepared, assures that I will never loose another.
2008 Genie S-65 65ft Telescoping Boom Lift (A50322)
2008 Genie S-65...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2015 JLG 6042 Telehandler (RIDE AND DRIVE) (A50774)
2015 JLG 6042...
Year: 2008 Make: Nissan Model: Sentra Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A51694)
Year: 2008 Make...
2016 Ottawa Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, 33,000 ... (A52748)
2016 Ottawa Yard...
2011 Ford F-350 Service Truck (A51692)
2011 Ford F-350...
