what size implements
   / what size implements #1
BWS
seattle area
kubota l3830 hst/723 fel
what size boxblade,rototiller and landscape rake should i get for my l3830?i will be picking up a 66-72"king kutter mower and figure i might as well get it all at once as a pkg.should eveything be 6'?i measured my back tires @ 73"[r-4's],are king kutter's other implements well built?seems like the mowers are the most bang for the buck?bws
   / what size implements #2
I've got a KK box blade, rake and scraper blade. For homeowner use they're great value and I'm completely satisfied. Not sure they'd hold up to the rigors of professional/landscaping use but no issues for me /w3tcompact/icons/smile.gif
   / what size implements #3
I think 6 ft is the way to go--To help you decide on pricing??--We sell a new 4 piece package like you described (or better) for $2800 + shipping--Ken Sweet
Sweet farm Equipment Co.
<A target="_blank" HREF=http://www.sweettractors.com>http://www.sweettractors.com</A>
   / what size implements #4
<font color=blue>...what size boxblade,rototiller and landscape rake should i get for my l3830?...</font color=blue>
Boxblade- 5-6' depending on what your grading/doing
(5' will allow you to be more aggressive)
Rototiller- 6'
Landscape rake- 7'
Rotary cutter-6' mowing a level field of grass low-med ht.
5' real brush hogging and all round use...
   / what size implements #5
JMIII -
Are you sure you'd consider a 5' box blade on a L3830?? I don't have the specs on that particualr tractor, but I believe it's significantly bigger than my NH TC33D. I use a 6' box blade on that with good results. I couldn't imaging going down to a 5' unit. It would not cover my tracks, for one thing.
John Mc
   / what size implements #6
As a general rule (ideally at least), you would like all your rear implements to be as wide as your rear tires PLUS a bit to make sure tracks are covered while driving straight or turning with the implement engaged. You can add a foot or so to a landscape rake because it doesn't deeply engage the ground.
Does the "38" in L3830 mean 38hp (or thereabouts)? If your rear tires measure to a 73" track, your tractor should have enough weight and power for implements sized using the guideline above and refered to by John Mc. For an example, my 24hp tractor has a rear track of 52" and came dealer equipped with a 66" boxblade. I asked about dropping down to a 60". They said I'd be happier with the extra width. I've never tried a 60", so can't say if I'm happier, but 66" seems to work fine.
Any implement, be it rear mower, brush hog, or box blade that is as wide or wider than the track of your rear tires will allow you to get close to a wall or whatever and still get the job done. The width of the tractor won't interfere with the action of the implement. Whether it is by design or by happenstance, tractors usually work fine with implements slightly wider than they are, but it depends on your needs, too.
Disclaimer: I am not familiar with your particular tractor. There are exceptions to "general" guidelines. As JMIII suggests, an aggressive application may require a narrower implement.
OkieG
   / what size implements #7
I run a 8' rake (KK 6' that I added 1' one each side)
on my 35D w/ no trouble also have a 74" bush hog
tiller but haven't used on the 35 D yet.
I did run the tiller on a L2900 and tore up sod w/
clay (very little topsoil) and 2 passes worked good.
I wouldn't go w/ anything less than 7',like other posts
u want to cover tracks and the rake angles so u lose
width.
ASSET DESCRIPTIONS & CONDITION (A53426)
ASSET DESCRIPTIONS...
2022 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2022 CHEVROLET...
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A53473)
2006 Magnolia Dry...
2021 Ford F550 XL 4x4 Service Truck (A52384)
2021 Ford F550 XL...
